Hello all,
I have some conversion issues (ts into mkv) because it is kicking out the DTS and leaving me only with the AC3 sound.
So I was thinking perhaps I can extract the DTS from the original file and reimport it into the MKV container ?
How do i extract a dts file from a ts one ?
here are the details from the original file.
Thanks a lot
Vidéo
ID de menu : 1 (0x1)
Format : MPEG Video
Version du format : Version 2
Profil du format : Main@High
Paramètres du format, Matrice : Par défaut
Durée : 29mn 17s
Type de débit : Variable
Débit nominal : 40,0 Mb/s
Largeur : 1 920 pixels
Hauteur : 1 080 pixels
Format à l'écran : 16/9
Images par seconde : 23,976 Im/s
Colorimétrie : 4:2:0
Type d'image : Progressif
Bits/(Pixel*Image) : 0.805
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Profil du format : MA
Durée : 29mn 17s
Canaux : 6 canaux
Position des cannaux : Front: L C R, Surround: L R, LFE
Echantillonnage : 48,0 KHz
Résolution : 24 bits
Langue : Anglais
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Durée : 29mn 16s
Type de débit : Constant
Débit : 448 Kbps
Canaux : 6 canaux
Taille du flux : 93,8 Mio (2%)
Langue : Anglais
			Closed Thread
	ONE similar topic is enough and I have already replied to your question. Continue in https://forum.videohelp.com/topic373094.html
  Extracting text from .caption fileBy dan2004 in forum SubtitleReplies: 3Last Post: 17th Nov 2011, 12:41
  Problems with extracting DTS from MKVBy Raf_a in forum Video ConversionReplies: 2Last Post: 5th Jul 2011, 02:44
  How i can convert dts-es to dts-core from one mkv file?By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 22:24
  Extracting/Editing DTS-HDBy sparktank in forum AudioReplies: 3Last Post: 28th Apr 2011, 13:11
  Extracting DTS-HD track with tsmuxerBy rantonio in forum Blu-ray RippingReplies: 3Last Post: 18th Mar 2011, 09:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
