After reading countless posts, I am running out of patience and have to ask. Is there a tool to demux a mkv file, and remux to Divx? I am asking because it seems like PS3 is only able to support soft subtitle in divx format, and I am having more and more mkv files, which is only playable on my PC.
By the way, I want NO TRANSCODING, so the quality of video/audio stays intact. Subtitles will need to stay as well.
Thanks.
@poisondeathray
I'm glad it's you, because I've been reading your posts at this thread.
https://forum.videohelp.com/topic356810.html
So besides the re-encoding for h.264, do you still recommend the steps from your post from the above thread? or is there a tool now that takes care the multiple steps? -
That thread was for DivX ultra players, not PS3
Search for "soft subs and ps3" and there are dozens of guides
But you still might be able to do it without re-encoding if your h.264 video is compliant (L4.1, not too many ref frames,etc..)by putting it into a transport stream. Try multiavchd -
Doing this sort of work once or twice is one thing. Doing it all the time is insane. I'd suggest you look into buying one of the newer media streamers such as the Western Digital HDTV player talked about here
https://forum.videohelp.com/topic358929.html
It's a lot easier to just play the files as is from a USB drive than to have to demux and remux stuff forever (and in a worst case scenario re-encode) just to support the PS3. However, it's your time and your money and you can do what you wish. I'm just suggesting an alternative.
Help me automating demux-remux dual audio files...
By CactusMan in forum Newbie / General discussionsReplies: 8Last Post: 6th Jan 2012, 21:59 -
Audio/video out of sync after demux-remux
By CarryNL in forum SubtitleReplies: 0Last Post: 14th Sep 2011, 15:31 -
80% MKV remux on H.264 - M2ts remux Aero Theme
By BJ12 in forum Video ConversionReplies: 2Last Post: 12th Aug 2011, 13:59 -
Capture out of sync after demux/remux (framedropping)
By Bingo-days in forum Capturing and VCRReplies: 3Last Post: 13th Jan 2010, 09:41 -
can not remux after demux
By volam in forum EditingReplies: 2Last Post: 19th Mar 2009, 16:36
