I had to move a low resolution monitor (max 1024x768) to a computer that has been configured for 1680x1050. As soon as I plug in the monitor I get a "out of range" message. I can start the PC in safe mode and it'll display properly, but is there a way to change the resolution settings so it starts properly in normal Windows?
thx
"Quality is cool, but don't forget... Content is King!"
Hit f8 after you start the computer and select enable vga mode.
Can't you change the video card settings in safe mode, then restart? If not, next would be uninstalling the video card driver in Device Manager and do a restart and it may reinstall properly. OR... I ran into a similar problem a few times and finally just pulled the video card, restarted, then plugged it back in and it reset it to default. Yeah, I know if it's a ATX MB, you just get a lot of beeps from no card. But it always worked.
EDIT: I forgot about VGA mode, worth a try.
Or just start in safe mode, delete the video card, then re-start. When the card re-installs, set the lower resolution.
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 07:57 -
Resizing video resolution and video quality
By Timex in forum Video ConversionReplies: 13Last Post: 23rd Aug 2011, 22:08 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
HD TV Resolution Problem
By jemoto in forum DVB / IPTVReplies: 9Last Post: 29th Mar 2008, 04:45
