  1. Member pchan's Avatar
    Mar 2003
    Singapore
    Hi,
    I have no problem converting rmvb using VirtualDub to AVI format on my desktop running Win XP. However, when trying using similar setup on my laptop running Vista, the conversion hang after 5 minutes. I am using K-Lite standard codec for both PCs.
    Any comment or suggestion to fix this problem is much appreciated.
  2. Member usta's Avatar
    Jun 2009
    Netherlands
    Try another converter.
    USA
    I use Any Video Converter Free Version for those type conversions. The pay version gets rid of the nag screen. Works on most all Real videos. You can save to HuffyUV and open that in VD if you need to edit. Or just output to Xvid or other more convenient formats.
  4. Member pchan's Avatar
    Mar 2003
    Singapore
    Thanks for all the comments.
    After numerous installing, uninstalling and reinstalling, it works.
    I have no idea what I have done right and what I have done wrong.
    Using Avisynth 2.58 and K-lite Codec 5.10 mega pack got it to work. 8)
    But the end results of the AVI is not meeting my expectation. Garbage in, garbage out.
