I'm using a A/D passthrough of my Canon camcorder to rip a ton of VHS tapes.. I'd like to transcode all the output to a format that will preserve as much of the DV quality as possible but maybe use 1/2 the disk space.
Is there a good codec / format that I should chose that will let me ditch these DV files with peace of mind?
Results 1 to 14 of 14
this depends how you plan on playing them back
you want to keep them on your HDD?
[vhs isn't a very good source but you're stuck]
I'll guess and say h264 in a mp4 container
but I have no idea at what I'm guessing... -
I want to have them in a format that I can do further processing and edit down later.
I realize if I transcode them I'll lose something.. but I want to keep that to a minimum. -
Don't bother. All encoders with higher compression will deliver lower quality and/or harder to edit files.
The only exception is if your final format will be DVD with less than 1 hour on a single layer disc, or two hours on a dual layer disc, most of your editing will be simple cut/paste, and you have a suitable editor. Then you might encode with DVD compatible MPEG 2 settings so the bulk of the material doesn't have to be reencoded while editing (only cut GOPs and transitions have to be reencoded). -
First I captured to DV format and then converted to MPEG2 with Vegas, it went from 40GB to 6GB/7GB after that I realized the best format to save is DV AVI. I know it takes lots of space, but in 5 years the Harddisk will extend and GB arent so much anymore. I think for the future.
The flag once raised will never fall! -
Since external HDDs are about $0.10/GB you can store DV (13.5GB/hr) for about $0.14/hour. A 1TB external USB drive will hold ~75 hours of DV (from 12+ 6 hour Video Cassettes) for under $100.
Of course, if you have hundreds of VCR tapes it could cost thousands of dollars.
After thinking about the costs and the fact that I have not looked at any of my tapes in many years, I bulk-eraser all but the few important (to me) tapes and donated the others to Goodwill.Andrew Jackson: "It's a poor mind that can only think of one way to spell a word." -
For most material those will give bigger files than the DV he's capturing.Originally Posted by creamyhorror
Hard drives are getting so cheap. For example 1TB ~$80, 1.5TB ~$120 and now 2TB ~$180.
Why invest in more labor to reduce quality?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Pair of Samsung 1.5 TB drives for US$99 each, free shipping:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152175
Slow but good for bulk storage. -
How I have my workflow setup is I have a script that will see new video and automatically transcode it so the labor isn't an issue.Originally Posted by edDV
I just would like to keep it in a format that is a little more compact if possible. -
Why if quality will be reduced? Are these camcorder videos or TV captures?Originally Posted by cowmix
I treat my camcorder material like gold but 98% of TV captures get converted to interlace MPeg2 or deinterlaced progressive MPeg4. VCR dub or TV to DV capture is great for speedy editing but most gets converted.Recommends: Kiva.org - Loans that change lives.
Oh, I thought he was capturing to uncompressed for some reasonOriginally Posted by jagabo
Alternate download locations
By teamsleep in forum ffmpegX general discussionReplies: 7Last Post: 22nd Apr 2012, 04:24 -
By MGadAllah in forum LinuxReplies: 1Last Post: 6th Nov 2011, 01:17 -
Free AMCAP Alternate?
By Mickz in forum Capturing and VCRReplies: 8Last Post: 4th Aug 2011, 20:13 -
lossless conversion to alternate containers
By krohm in forum Video ConversionReplies: 33Last Post: 12th Jun 2009, 03:19 -
Ripping DVDs with alternate angles
By Jeikobu in forum MacReplies: 0Last Post: 26th Aug 2007, 18:25
