I have an AVI file and it will not play for me, I get the error saying it is an unsupported format. I am trying to play this .avi file on my Xbox360 from a USB stick. I have used 4U avi mpeg program and converted it to MPEG1 and MPEG2, but still no luck. How can I convert it to a format that is supported now? Is there a program that will do this for me? I heard MEGui modern media encoder will do it, but I could not figure out how to use it.
Please help, thank you in advance.![]()
What format is the file? AVI is just the container name, it covers dozens of formats/codecs from DV to H.264. Drop it into MediaInfo or Gspot and let us know what it really is. And you might also check to see what a Xbox360 is capable of playing. It may just be out of spec or may be a format it can't play. Either way, you should be able to convert it to something usable.
Ok, I checked on the formats that are supported by the xbox360. Here is a link for them :
http://www.afterdawn.com/guides/archive/what_will_xbox_360_play.cfm
Or this link
http://blogs.msdn.com/xboxteam/archive/2007/11/30/december-2007-video-playback-faq.aspx
I used Media Info and got the specs on my AVI file:
1 video stream: MPEG-4 Visual (DivX 3 Low)
1 Audio stream: MPEG Audio (MP3)
What do I use to convert this to one of the supported formats?
Thanks -
Hi tim_ver,
What comes to mind quickly for me is that I see your MPEG-4 file is encoded with DivX 3, which is really, really old. I do not own an Xbox but I've had some standalone DVD players that have been really picky about what codec was used for the MPEG4 video, and also some individual settings used while encoding make players choke as well.
You could convert the video to DVD using ConvertXtoDVD, which will create a DVD for you.
As for staying in AVI format, if a re-encode is what is needed, you'll lose a lot of quality. If the file you have was sourced on say, a DVD, I'd use the DVD to make a new AVI file instead of converting AVI-->AVI. Or just play the DVD come to think of it
If you just need a quick and easy re-encode, you could try Any Video Converter Free Version. It does have output modules for Xbox 360 that 'should' be compliant with your machine. It's a easy program to use. Just make the output as Xbox 360 compatible and try to use similar settings as the original file, framesize, framerate. If it doesn't work for you, all you've lost is a bit of time. Any re-encode will cause some quality loss. If your original file is low quality, you have little to lose. If it's high quality, then give it a try, but keep the original file and you can try other conversion methods later.
If it works for you, consider purchasing the retail version and you will eliminate the 'nag' screens. I can tell you, as mentioned, Low motion Divx 3 is a really old format and you will likely have to convert it to something else for the Xbox.
Good luck and keep us informed.
MPC with K-lite codec pack won't play ISO movies in Windows 7
By Monsoon in forum Newbie / General discussionsReplies: 9Last Post: 5th Dec 2010, 21:28 -
video file won't play. need to know what type it is - what codec?
By chriscaton in forum Video ConversionReplies: 7Last Post: 12th Jan 2010, 08:20 -
AVICodec tells me I have the correct codec but video won't play.
By lesbianvirgin in forum Newbie / General discussionsReplies: 1Last Post: 5th Jan 2009, 01:38 -
xbox360 won't play this avi,, codec info inside
By sance in forum Media Center PC / MediaCentersReplies: 11Last Post: 24th Dec 2008, 12:11 -
.MP4 to .AVI Conversion Issues - Loss of Sound, Won't Run to Completion
By gumrunner505 in forum ffmpegX general discussionReplies: 1Last Post: 10th Oct 2007, 19:49
