I demuxed VOB files to elementary streams, m2v, ac3, mp2, wav. I want author DVD with basic menu, just list or tracks. I want author without re-encoding files. I have read, TmpGenc DVD Author is unpredictable in this task. Is there better tools? TDA is very handy for menu creation, though. I have TDA v2x
Results 1 to 11 of 11
Read my blog here.
DVD Styler seems the only one of the above that is actively developed.
GUIForDVDAuthor is well supported here by it's author
Read my blog here.
TmpGenc DVD Author never re-encodes any files thats dvd compatible,lot of people just have downloaded mpgs and avi that that need re-encoding.Just use your tda 2.
I highly suggest Ulead DVD Workshop 2, which is available for $99 from this link. This program used to be almost $500, and it is arguably "professional" class software, not low-end hobby software. However, the beauty of DVDWS2 is how click-easy it is to use, while staying so incredibly powerful.
A video-based guide is at http://www.digitalfaq.com/forum/showthread.php/author-ulead-dvd-1506.html
However, all that said, there is NOTHING wrong with TDA (now TAW4). Guide and information on this software at http://www.digitalfaq.com/guides/video/author-tsunami.htm
Whatever you have read is probably misleading crap from somebody that didn't know what they were doing.Want my help? Ask here! (not via PM!)
I looked but didn't find detailed guide how to create menus with GUIForDVDAuthor. I dont need cut-edit, chaptering, subtitlemenus, DVD will have only multiple tracks and no chapters; so need set each mpeg file as a sepapate clip (on separate track), each track contain one clip (should work just similar way as we have chosen 'Top menu only' in TDA menu structure).
Is the DVD Maestro completely obsolete tool? Which functions or standards are not supported by DVD Maestro? -
He's done some bugfixes., eg https://forum.videohelp.com/topic366080.html#1964459Originally Posted by ZQX
Regardless, GfD is a quite mature program and does the job very well as-is.
LINUX: AVI to DVD Encoding and Authoring : BASIC
By disturbed1 in forum User guidesReplies: 13Last Post: 5th Feb 2010, 20:43 -
the best setting for encoding and authoring hd to make a avchd dvd-r and bd
By LEONESVIZZERO in forum Authoring (Blu-ray)Replies: 3Last Post: 8th May 2008, 07:22 -
DVD authoring and encoding on TMPG and Ulead
By bellyting in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2007, 16:53 -
DVD Authoring: Menu Creation, Encoding, etc
By kerpal in forum Authoring (DVD)Replies: 7Last Post: 20th May 2007, 18:27 -
Regarding MPEG2 Encoding (DVD authoring)
By Wuhtzu in forum Video ConversionReplies: 9Last Post: 10th May 2007, 17:07
