VirtualDub has an audio filter called "format convert"; however, it doesn't tell me how to use it. It only has an integer field called Precision, which defaults to some number depending on the incoming stream's sampling rate and bit depth. When I feed it a 16-bit 16kHz mono stream, it defaults to "3". How do I use this filter?
If you want to know why I am asking this question:
I want to convert a 48kHz 16-bit stereo PCM stream to a 16kHz 4-bit mono ADPCM stream that I can later insert into a YM2608+ADPCM (NEC SpeakBoard: 6FM+3SSG+2Rhythm+ADPCM) chiptune. Wavosaur cannot go below 8-bit depth, and it doesn't handle ADPCM WAV files.
Results 1 to 1 of 1
VirtualDub: "AVI Import Filter error: (Unknown) 80040154"
By Xavier in forum Newbie / General discussionsReplies: 11Last Post: 15th Dec 2021, 18:49 -
Using VirtualDub's "capture filter" proc amp
By sanlyn in forum Capturing and VCRReplies: 3Last Post: 31st Jan 2012, 08:13 -
VirtualDub Error 'Says "Couldnt locate decompressor for format xvid"
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2010, 00:05 -
VirtualDub Filter for problem with "Horizontal Sync Issues"?
By lonerzzz in forum RestorationReplies: 6Last Post: 6th Apr 2009, 18:29 -
Vdubmod "Source image format incorrect" when cropping with filter
By Gruelius in forum Newbie / General discussionsReplies: 4Last Post: 22nd Dec 2008, 20:37
