Will there be a noticeable difference in quality when you go to render vegas pro and put the audio with the video? There is that option to render the audio separately or together. How much better would the one be than the other? Thanks.
It should be the same assuming you used the same export settings, project setttings, etc...
Sony Vegas Pro 10 - video/audio out of synch after render
By Acester47 in forum EditingReplies: 4Last Post: 1st Jul 2011, 15:06 -
Audio/Video Sync in Vegas Pro 9?
By TiLoBrown in forum EditingReplies: 4Last Post: 6th Sep 2010, 15:29 -
Sony Vegas 8 Pro - No audio stream for MPEG-2 video
By tarrickb in forum Newbie / General discussionsReplies: 10Last Post: 9th Jan 2010, 16:45 -
Resyn audio with video using Vegas Pro
By 7saigon5 in forum EditingReplies: 0Last Post: 28th Nov 2009, 09:22 -
Putting a copyright on your dvds with Sony Vegas Pro 8.1?
By ingeborgdot in forum EditingReplies: 62Last Post: 11th Nov 2008, 20:08
