I was considering that SXVCD and DVD use the same resolution.
So, shouldn't it be convenient to use an SXVCD format with higher resolution the normal SVCD and "normal" SVCD Kb/s rate to help the encoder engine in the encoding process?
The idea is if working with same frame dimension should speed up considerably the work.
Has the idea an algorithmic feedback ?
Giuliano
First off XSVCD may have any resolution. I guess you mean 720x480/576. Then you do not need to resize--->faster encoding.
But you have to encode a 50% larger framesize---->slower encoding.
At the end dvd to 720x480 xsvcd will take longer than dvd to svcd.
Also it is a bad idea to use D1 resolution without increasing the bitrate.
Can you reduce video (MKV/H.264) Bitrate withOUT re-encoding?
By KushSmoka420 in forum Video ConversionReplies: 4Last Post: 14th Mar 2012, 04:17 -
How do i reduce encoding times,
By jamesj84 in forum Blu-ray RippingReplies: 5Last Post: 14th Feb 2012, 05:55 -
How I can reduce the time consumption?
By ramz in forum EditingReplies: 11Last Post: 7th Jun 2010, 10:42 -
too long time for encoding .ts files
By Benjy in forum Video ConversionReplies: 3Last Post: 24th Mar 2010, 05:06 -
Encoding with VirtualDub the second time around is very slow
By Megahurts in forum EditingReplies: 9Last Post: 6th Mar 2008, 23:02
