or not![]()
I made a HD-BURN disk that plays with no problem on my computer, but, when I try to play it on a DVD player I get either an Unrecognizable or Incomparable error message.
In fact, on my APEX, any disk I tried to play after tring to play the HD-BURN disk was taged as Unrecognizable until I turn the unit off and on again![]()
I have read some of the other message about thses disk, but, I just want a clear answer.![]()
Some information on HD-BURN for others reading this, that I found: http://www.digital-sanyo.com/BURN-Proof/HD-BURN/index.html
However, the writer/drive has to support writing and reading the disc - and last I heard, few did.
Since this is a non-standard way of writing to a CD, it's unlikely most set-top DVD players will recognize any discs created this way. Not sure about Sanyo's players, though.If cameras add ten pounds, why would people want to eat them? -
HD-BURN only works in Sanyo/Optorite writers but they are out of business now, I had an Optorite writer and made a few HD-BURN CD's but none of them worked in anything but my writer. HD-BURN was a good idea at the time but it was obsolete when DVD media became affordable.
Well, I burn a HD-BURN disk usinng a "regular" Philips CD-R and my CyberDrive CD burner with it seems no problem.However, the writer/drive has to support writing and reading the disc - and last I heard, few did.
And both it and my BENQ DVD burner both "see" it as a DVD.
Yet, something like DVD decripter don't see the disk as a DVD or even if anything is on it.
However, it also seems that the second of the 2 videos on the disk has some kind of problem in the middle of it since the video will freeze at one point. However, Both burners WILL play the menu page and the first (shorter) video with no problem. I am just wondering, especially since you write that there very few such units, that did I "luck out" by having both of my burners be able to use HD-BURN?
Plus, can it be since there is a problem with one of the videos that it could be the reason why "regular" DVD players can't read HD-BURN disk?
Or that I did not use my DVD burner to burn it?
Or, as you kind os implied, HD is dead
No, the DVD players won't recognize it, for the most part, because it's a nonstandard CD format. The data is written to the CD in a way that most of the players won't recognize.
Do all DVD players deinterlace DVDs made from mini-dv camcorders?
By granturissimus in forum Newbie / General discussionsReplies: 12Last Post: 16th Jan 2011, 20:01 -
are there any blu-ray players that can be made region free for dvd's?
By CODEWERKX in forum Newbie / General discussionsReplies: 2Last Post: 25th Sep 2009, 13:26 -
Rip a strange work made DVD
By jntaylor63 in forum DVD RippingReplies: 5Last Post: 22nd May 2009, 05:45 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
home made DVDs wont play on all stand alone DVD players. why?
By suomiaussie in forum Authoring (DVD)Replies: 12Last Post: 2nd Jan 2008, 20:59
