This software (m4a-to-mp3-converter) can be used to convert 32kbps AAC parametric stereo to 64kbps mp3 stereo. Can also be used to convert to/from other bit rates.
Software URL:
http://www.maniactools.com/soft/m4a-to-mp3-converter/?ref=m4a-home&version=6.1&b=6100
Important: When you install the software, make sure to uncheck the adware options which will install by default
Following is link to 32kbps parametric stereo AAC file:
http://www.fileden.com/files/2006/11/30/441298/Channel.aac
Note: VLC player will only convert this type of file to mp3 mono, so m4a-to-mp3-converter software is better.
Good use for this software. Follow these 3 easy steps:
1) Use StreamHijacker to rip 32kbps AAC stream. If you like classical music, good stream to rip is:
http://198.234.121.114:90
You can rip all day and use very little disk space and CPU power. Sound quality is good.
Note: This is 32kbps AAC stereo stream and if you have slow internet, I think this is easier to rip than 128kbps mp3 stream.
2) Use m4a-to-mp3-converter to convert to 64kbps stereo mp3
3) load converted file onto your mp3 player and enjoy
Results 1 to 15 of 15
Audacity 1.39 can open this and save it to any format you like.Originally Posted by jimdagys
Presumably since it uses ffmpeg to convert input/output, you could find other ffmpeg tools/guis that would also handle it.
However, it only sees mono audio.
I am suspicious of whether there is stereo at all in this.
Are you sure your tool is finding and converting real stereo, or just duping the mono channel?
Load up the MP3 in an audio editor and it should be obvious if both channels are identical.
I loaded these files (ripped and converted according to above 1,2,3 recipe) on my mp3 player and they play in rich beautiful stereo. My ear tells me that.
I am kind of curious how you load this AAC file
into Audacity. I have Audacity 1.3.9 Beta (unicode) and I cannot properly load the file. I don't get any waveform pattern shown at all. Converting to mp3 yields nothing. Can you tell me how you loaded it into Audacity?
As I said, using the ffmpeg plugin.Originally Posted by jimdagys
http://manual.audacityteam.org/index.php?title=FAQ:Installation_and_Plug-Ins -
Did you install it in Audacity, as the instructions?Originally Posted by jimdagys
http://manual.audacityteam.org/index.php?title=FAQ:Installation_and_Plug-Ins#2._Installation -
Located automatically and also by manual method. Still can't load the above AAC file.
I have Audacity 1.3.9 Beta (unicode). Can't load the AAC file (http://www.fileden.com/files/2006/11/30/441298/Channel.aac) properly. Maybe I will just give up on this.
sound forge 10, dbpoweramp, and mediacoder all claim this file is damaged and unusable.
Get a recent version of Mplayer, and try this command-line:Originally Posted by aedipuss
It should generate a correct and playable stereo .WAV,Code:mplayer Channel.aac -vc null -vo null -ao pcm:fast
regardless of any warning/error messages displayed on the cmd window. -
And here's a very technical thread on Doom 9 on how to load AAC in Avisynth:
http://forum.doom9.org/showthread.php?t=114941 -
BTW
I do not see any problems with conversion (this example AAC file) using audio converter from AIMP player, also used convert option in foobar2000 player.VideoAudio.pl - Serwis o technologii wideo & audio
MKV AAC GUI Converter with Nero AAC Codec
By prijatelj.v in forum AudioReplies: 4Last Post: 26th Mar 2012, 09:41 -
All-In-One Downmixer-Converter For .aac?
By LouieChuckyMerry in forum AudioReplies: 0Last Post: 13th Jan 2011, 01:14 -
M4a to AAC Converter
By Dave1024 in forum AudioReplies: 6Last Post: 27th Jul 2009, 22:44 -
Found an excellent freeware DVD copy tool...
By Djard in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2008, 20:17 -
aac converter
By Shaorin in forum Newbie / General discussionsReplies: 1Last Post: 21st Jul 2007, 09:20
