Hey guys
I'm new here. My PC is running Windows Vista 64-bits. I have installed Vegas 8, 8.1-64-bits and 9 on my PC.
Things happend yesterday, when I upgrade my iTunes from 8-64-bits to 9-64-bits. and it also automatically install Windows Update(09/10). The Vegas stop recognising .m4a audio file. discarding which version of Vegas you use.
I uninstall iTunes 9 and Windows Update and reinstall Vegas 9. But the problem is still there.
Does anyone encounter the same problem like this? I think one of these updateing must cause that problem. I can still play .m4a using iTunes 8,9 or QT, and AE CS4 can also play .m4a as well. only not for Vegas. I'm really in the deep shit. any help?
try changing the extension to .mp4 or convert the file to a working format like .wav or somesuch
We have exactly the same problem. Vista 64 bit, Vegas 8.0d, and iTunes 9. All was good until we updated iTunes. Now Vegas doesn't recognize mp4 and m4a audio (error is "audio stream properties not recognized"). We backed out the Windows updates, and updated Vegas (from 8.0a to 8.0d). Still no luck. At least now I know I don't need to uninstall iTunes!
Help! I am going to miss a deadline if I can't get this working.
Sony Vegas can't recognize files
By coxanhvn in forum Newbie / General discussionsReplies: 3Last Post: 23rd Apr 2011, 05:23 -
Can Vegas Pro 8 be made to recognize HuffYuv?
By brassplyer in forum EditingReplies: 3Last Post: 11th Apr 2011, 18:31 -
problem: flv files don't open in Vegas pro 10
By freestyler09 in forum EditingReplies: 2Last Post: 25th Feb 2011, 13:57 -
Stop motion softwares don't recognize capture card
By Greycat in forum Capturing and VCRReplies: 4Last Post: 26th Jul 2009, 19:22 -
comp wont recognize older cd's & dvds
By lawzfeehily in forum Software PlayingReplies: 6Last Post: 12th Sep 2007, 17:56
