Sorry about my last post
This is what i have done. I have two avi files that i demuxed, then i used Cutterman to make 8 indiviidual vids
using Dvdpro2 i competed the rest including adding menus. in the end i burnt the dvd with dvdpros burner.
I have a Phillips DVDr615 recorder player, the medium is Sony dvd+r
When i try to play the said dvd it just starts playing the first vid it does not go to the menu.
Hope this is more helpfull
Thank you
Closed Thread
I'm not familiar with the software your using, but it may be that you have authored with a setting like 'when disc inserted play first video', rather than 'go to menu' (or something similar).
If your DVD player has a 'menu' button, press that and see if it goes to the menu. If so, the menu is there but you will need to re-author it to display menu first.
No need for a new topic, continue in https://forum.videohelp.com/topic372841.html .
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 05:15 -
Any Programs Have Better System than Long Play, Extended Play?
By johnharlin in forum Video ConversionReplies: 3Last Post: 10th Jul 2009, 19:04 -
How do I play/convert .MP4 files to play on my laptop
By tfoster in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2008, 20:23 -
how to play mp3's randomly in folder without play lists
By deejay.2001 in forum Software PlayingReplies: 4Last Post: 22nd Apr 2008, 13:27 -
Avid Lquid 7 menus..play chapter and play all
By cheesypuffs in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2007, 01:34
