Hi,
my goal is to build a video presentation, using mostly photos, short videos and audio files. In other words, a kind of elaborated slide show BUT I need many transition effects specially between the photos AND the possibility to export the presentation with a size of 1024 x 768 px. as the presentation will be shown with a video projector using this res.
My budget is under $200.
I've searched the web and found Power Director 8, which could be the right solution for me as I'm a newbie in Video editing.
The problem is I'm using a laptop and I'm afraid my Processor
won't be fast enough (although I don't plan to import DV ).
here are the details:
my Processor : AMD 64 athlon 3200+ | 1994 MHz
From what I've read, Power Director 8 requires a processor of 2,2 GHz.
Will my pc be able to handle it?
Is it risky to install PowerDirector since my processor seems too weak for it?
Thanks for your help
I use Magix Movie Edit for just that scenario(except the output size) and I love that little program. Jpegs, MP3s, mjpeg from my camera....it takes it all and it's very easy to use.
Proshow Gold and Proshow Producer will both do what you are looking for in terms of building the show from the asset types you are listing.
As for output, I know Proshow Producer can be set to output 1024x768 px but I'm not sure if Gold can.
--dES"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
Nothing bad is going to happen from the install, it will just run slow. Like rendering a 2-hour presention will take a day or so.
Work in small chunks while testing, unless you have LOTS of time.
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 03:18 -
BD - Re-builder problems
By GremlinMaster in forum Blu-ray RippingReplies: 2Last Post: 15th Jun 2010, 16:44 -
Possible BD Builder issue???
By saltyjd1 in forum Blu-ray RippingReplies: 23Last Post: 28th Feb 2010, 21:27 -
Blocks / Pixellation after BD Re-Builder or DvdFab
By PhilippeB in forum Blu-ray RippingReplies: 20Last Post: 19th Oct 2009, 20:32 -
PE Builder Boot Disk
By scustalow in forum ComputerReplies: 2Last Post: 14th Nov 2007, 14:21
