    Sep 2009
    Israel
    When I encode a MKV file to AVI, the audio of the AVI suddenly has over 1500 kbps, when I only need 128 kbps. This gives the file insane size, which is useless, since there's no difference.
    How do I change the audio settings in VDMod?
  2. streams=>streams list=> right click and select full processing mode => right click select compression
    If your audio format is compatible in AVI container , you can just direct stream copy without losing quality
    USA
    It probably passed the audio through without encoding. If you want to encode the audio to MP3, I would install Lame MP3 as it has more options than the default MP3 encoder.
    In VD Mod, you go to 'Streams>Stream list'. R click on the audio stream there and select 'Full processing mode'. R click on the stream again and select 'Compression' and you should have your choices shown. VDM can't always handle direct conversions between audio formats, so if I have problems, I save out the audio as a WAV with full processing and use Audacity to edit or modify the audio, then add it back in with the video.
    And welcome to our forums.
    Sep 2009
    Israel
    Ok, thanks
    Sep 2009
    Israel
    Is there a way to make VDM choose full processing mode automatically, so I wouldn't need to manually change it for every file.
