I converted this file with AVStoDVD:
Video: Xvid 720x304 25.00fps [Video]
Audio: MPEG Audio Layer 3 48000Hz stereo 114Kbps [Audio]
and as output i have two files, an .m2v ( MPEG2 Video 720x576 (16:9) 25.00fps 9000Kbps) and a .ac3. The .m2v does not have sound. I tried to merge these two files with Muxman, and in the output .vob files there is not sound.![]()
Results 1 to 11 of 11
First confirm there's no sound in the VOB by opening it in GSpot and having a look in the audio section. Next get the Muxman log in the root of the C drive and see if the audio was rejected and why.
They never do. It's a video only elementary stream. Are you sure that Avs2DVD isn't supposed to author it for you?The .m2v does not have sound.
http://avstodvd.googlepages.com/homeDVD Authoring using MuxMan/BatchMux
If there's an Avs2DVD log, post that here. Perhaps the Avs2DVD developer will see this thread and solve your problem. -
The Audio section is blank.Originally Posted by manono
This is the muxman log
Code:MuxMan version 0.15R Accepted video E:\AVStoDVD\DVD_2_***.XviD.m2v size = 8750828 Accepted audio E:\AVStoDVD\DVD_2_***.XviD.ac3 12:45:00 Begin multiplex VTS01. Title Segment List Segment_1 Maximum audio duration 2 fields. Starting scene Segment_1_scn1 at 00:00:00:00 SeqEnd at 1008586E8. Bytes remaining in buffer = 0. Bitrate - avg: 4013406, min: 191146 (lba 2035171), max: 9128228 (lba 660734). Shortest GOP has 4 fields, longest GOP has 30 fields. Fields: 438494, VOBU: 14855, Sectors: 2148260. 12:56:04 Begin multiplex VMG. 12:56:04 End multiplex.
With a previous video i converted with Avs2DVD, i had the dvd files ready. I don't know what happened now. I didn't change any settings.They never do. It's a video only elementary stream. Are you sure that Avs2DVD isn't supposed to author it for you?
Yep there is a log.
...where "***" is the file name or the directory and the file nameCode:<9/9/2009 11:35:54 μμ> START PROCESS <> <9/9/2009 11:35:54 μμ> PROJECT SETTINGS DVD Video Standard: PAL DVD Titles number: 1 DVD Size: 4435/4435 MB (100%) DVD Output Setup: DVD Folder DVD Label: DVD DVD Menu: No Menu Output Folder: E:\AVStoDVD Save Log file: Yes Delete Temp Process Files: Yes Delete Working Files: Yes Edit Command Parameters: No Post Process Task: Show Progress Status window <> <9/9/2009 11:35:54 μμ> TITLE 1 SOURCE FILES Video: E:\***.avi Info: XviD - 1157 kbps - 720x304 - DAR 2,368 - 25 fps - Progressive - 2:26:09 hours - 219247 frames Audio: E:\***.avi Info: MPEG-1 Audio layer 3 - 114 kbps - VBR - 48000Hz - 2ch - 2:26:09 hours Subs: [MediaInfoLib - v0.7.19] <> <9/9/2009 11:35:54 μμ> AVISYNTH SCRIPT Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi") Video = A2DVideoSource("E:\***.XviD.avi", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp") Audio = A2DAudioSource("E:\***.XviD.avi", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp") Video = Video.ConvertToYV12 Video = Video.AddBorders(0,50,0,50) Video = Video.Lanczos4Resize(720,576) Audio = Audio.EnsureVBRMP3Sync() AudioDub(Video, Audio) <> <9/9/2009 11:35:54 μμ> START VIDEO ENCODING OPERATIONS Encoding Profile: HCenc VBR 2-pass Target Video FileSize: 4103,5 MB HCenc Parameters: -ini "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_2_***.XviD.HCenc.ini" HCenc ini file: *INFILE C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_2_***.XviD.avs *AVSRELOAD *OUTFILE E:\AVStoDVD\DVD_2_***.XviD.m2v *LOGFILE C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_2_***.XviD.HCenc.log *MAXBITRATE 9000 *BITRATE 3925 *PROFILE BEST *ASPECT 16:9 *PROGRESSIVE *BIAS 40 *DC_PREC 8 *MATRIX MPEG *AQ 1 *LUMGAIN 0 *SMP *PRIORITY IDLE *WAIT 2 <> <10/9/2009 3:41:58 πμ> END VIDEO ENCODING OPERATIONS A2DVideoSource: AVISource Created File: E:\AVStoDVD\DVD_2_***.XviD.m2v (4104,3 MB) OUTPUT VIDEO INFO: MPEG-2 Video - 3989 kbps - 720x576 - DAR 1,778 - 25 fps - Progressive - 2:26:09 hours - 219247 frames <> <10/9/2009 3:41:58 πμ> START AUDIO ENCODING OPERATIONS Wavi+Aften Parameters: "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_2_***.XviD.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 - "E:\AVStoDVD\DVD_2_***.XviD.ac3" <>
There's something very wrong with the audio that was created:
I checked a Muxman log of a movie I had recently authored:Maximum audio duration 2 fields
What happens when you play the AC3 audio? It doesn't quit immediately? You got a working nearly 2.5 hour AC3 file out of it? If that's the complete Avs2DVD log, it looks to me like it quit during the encoding of the audio, and there's no mention of the audio encoding finishing or of the muxing. I don't use the program, so perhaps someone else can provide more information.Maximum audio duration 451806 fields. -
Yes it almost quits when you open it, and i expected to be something like the audio for the whole movie...
Thanks anyway
problem with Muxman Audio
By ramimahafza in forum Authoring (DVD)Replies: 1Last Post: 26th Jun 2011, 00:38 -
problem getting chapters with MuxMan
By alivecamel in forum Authoring (DVD)Replies: 4Last Post: 25th Aug 2010, 02:49 -
problem with muxman
By heof in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2009, 06:04 -
Problem with muxman
By biffo in forum Authoring (DVD)Replies: 5Last Post: 11th Dec 2008, 16:26 -
Problem with remuxing with MuxMan
By omega6666 in forum Authoring (DVD)Replies: 13Last Post: 25th Aug 2007, 17:14
