I want to connect my computer to my flatpanel hdtv. I do not have dvi or hdmi on my computer so i am just going to use a vga cable. My qs is should i get a svga cable ? what is the diff. which will work better. Thanks
The names are pretty much used interchangeably. Technically, a VGA cable must only carry 640x480 60 Hz analog video, SVGA 800x600 60 Hz. But most VGA/SVGA cables are capable of carrying much higher resolutions (1600x1200, 2048x1536) and refresh rates. The differences between different quality (S)VGA cables will show up as blurry images. Most HDTVs that accept (S)VGA will top out around 1280x1024. So the cable will rarely be problem. Unless you are running very long cables.
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 09:31 -
PC VGA to VGA on LG 42" Plasma
By Squirralien in forum Media Center PC / MediaCentersReplies: 3Last Post: 8th Nov 2008, 21:43 -
laptop with only VGA to VGA-less HDTV
By liiam in forum DVB / IPTVReplies: 0Last Post: 16th Oct 2008, 15:16 -
SVGA and VGA?
By warlock110 in forum ComputerReplies: 1Last Post: 11th May 2007, 20:07
