  1. I'm trying to convert the clips I've downloaded off Youtube(HD) using VirtualDub, but the problem is with Xvid compression and Lame MP3 audio, the video bitrate always comes down to 1kBps even if I set it to 125Kbps(=1000kbps)... this used to work for me before, but now virtualdub doesn't even decode the video frame when I shift somehere to the middle of the video... I've installed the K-Lite Mega Codec pack 5.10 and have a few filters in the plugins folder of Virtualdub... The properties of the video file as reported by Mediainfo are as follows:
    General
    Complete name : C:\Documents and Settings\Karthik & Ashwin\My Documents\Downloads\Video\YouTube - Plain White T's - Hey There Delilah (HD).mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 59.9 MiB
    Duration : 3mn 56s
    Overall bit rate : 2 125 Kbps
    Encoded date : UTC 2009-02-14 00:55:00
    Tagged date : UTC 2009-02-14 00:55:00
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : avc1
    Duration : 3mn 56s
    Bit rate mode : Variable
    Bit rate : 2 001 Kbps
    Maximum bit rate : 3 439 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.091
    Stream size : 56.3 MiB (94%)
    Title : (C) 2007 Google Inc. v08.13.2007.
    Tagged date : UTC 2009-02-14 00:55:01
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 3mn 56s
    Bit rate : 124 Kbps
    Maximum bit rate : 169 Kbps
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 44.1 KHz
    Resolution : 16 bits
    Stream size : 3.48 MiB (6%)
    The audio too, doesn't encode at all... The Audio data in the status windows says 0...
    The plugins in Virtualdub are:
    DShowInputfilter.vdf and MP4InputDriver.vdf... Can any of me tell me whats going wrong??
    Probably because of the avc video. Try something else like handbrake, xvid4psp or avidemux or do you have to use some virtualdub filters?
  3. well, yeah the problem is I've got only 224MB of RAM... So VirtualDub is the only feasible option... The vid converts in Virtualdubmod with a Avisynth script, but the output is too pixelated... So that is out... Beyond that I've no idea... I could do this no sweat before, but I dunno, of late it doesn't seem to be working...
