Hi,
looking for suggestions on what player to use for an expo - i need to show a list of around 10-20 demo clips off a TV. The list needs to restart so the clips go on and on forever.
The clips are computer rendered/animated. They are from 10 seconds to a few minutes, and between every clip there's a short "filler" with a black text on white background, also a video clip, but just a few seconds long.
I could just go with VLC, the only problem is that it gets minimized between every clip, so the impression is a bit "jerky". I would prefer something that does relatively smooth transitions from file A to file B.
Will be playing from Windows XP.
I think i would prefer some kind of mplayer solution - which of the GUIs would you reccommend?
I dont mind "scripting" this from some text file, if necessary. Especially since some of these clips are "fake anamorph". They are produced as 4:3 but basicly needs to be played with an explicit 16:9 force. Then again some of the clips are 4:3. And some are "real" 16:9.
A bunch of codecs as it seems, everything seems to be manageable by VLC though.
Thanks for the advice.
Does anyone know a good way to script mplayer (or some other player) in a way that you can define how individual files will be played? Aspect ratio settings and such.
Also, regarding the transitions, what is the most "smooth" player in your opinion? I want the jump from one file to another to be as subtle as possible.
transitions hard to add on multiple clips in premiere
By codemaster in forum EditingReplies: 11Last Post: 7th Jan 2011, 12:34 -
Sony Vegas Pro 8 ... transitions application on multiple video clips ???
By holeepassion in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2010, 02:04 -
asf playout on second monitor from playlist not smooth at transitions (WMP)
By pj0tr in forum Software PlayingReplies: 1Last Post: 3rd Sep 2008, 15:45 -
Transitions between separate video clips ??!! no possibilities..
By Harviz in forum Authoring (DVD)Replies: 2Last Post: 30th Nov 2007, 10:04 -
Smooth transitions in playlist? media player classic
By Voodooman in forum Newbie / General discussionsReplies: 5Last Post: 17th Oct 2007, 16:45
