I'm converting some xvid.avi files to xvid.mp4 and playing them on a portable player.
In the conversion process, I have to set B-frames to zero, otherwise the player fails to play the video. I've confirmed this with Mediainfo showing BVOP "YES" before conversion, and BVOP "NO" after conversion.
Is there a way to remove b-frames from a video (set them to zero), without the lengthy process of encoding?
Pity.
How about a faster method of encoding: all other aspects of the avi stay the same (resolution, fps, bitrate, codec, etc..,)?
In addition, the audio stream can be simply copied.
So, which tool could perform video only encoding and leave out the BVOP in a fast way?
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
bvop, pvop, nvop
By Anonoumus in forum Video ConversionReplies: 5Last Post: 22nd Jul 2009, 22:20 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
I am viewing some movies. If BVOP is off. Would it not play on standalone?
By rocky12 in forum Newbie / General discussionsReplies: 14Last Post: 27th Nov 2008, 08:32 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
