Here are a few questions I am hoping you all can help me out with...
In TMPGEnc, is there anything really wrong with setting the lower and upper bounds of VBR to 0 and 9000? I relize the bitrate could spike in those cases, but does it really make that much of an issue?
Does SmartRipper produce video files that are larger then they would be in their natural state? I have run a few tests and am able to cut the size of these files in half by re-encoding them in TMPGEnc, with no noticible artifacting... is there a loss of quality I haven't noticed yet?
If I am ripping a DVD, adding subtitles (through the authoring software) and re-burning it, should I use the files that come out of SmartRipper or should I re-encode to get the filesize back down? With quality being something I want to maintain.
Thanks for any help!
Hoag
Results 1 to 1 of 1
How do I pick settings to optimally re-encode video for reduced file size?
By bootyhound1 in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 15:16 -
TMPGEnc Maximum File Size for Authoring?
By cym in forum Authoring (DVD)Replies: 3Last Post: 26th May 2010, 01:55 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 20:48 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 14:30 -
CBR vs VBR with same file size.
By PuzZLeR in forum Video ConversionReplies: 13Last Post: 18th Jun 2007, 01:47
