Results 1 to 12 of 12
  1. Member romanstopme's Avatar
    Mar 2008
    My friend got a laptop Hp pavilion dv4000. The person who he got it from broke the screen completely so i ordered a new one. put it on works great but when i turn the pc on i get the blue screen of death after windows starts to load. i tried to change the boot order but the pc asks me for a bios password witch i don't know. So when i turn the pc on i can change where it boots from by pressing ESC but when i click the cd drive it just has the black screen like for a min and then loads it from the hard drive. What is the problem is it the dvd im using as a boot or the pc?
    We don't stop playing because we grow old; we grow old because we stop playing.” (George Bernard Shaw, 1856-1950)
  2. Member romanstopme's Avatar
    Mar 2008
    xp home edition was installed before i downloaded a iso same xp home edition put it onto a dvd and it wont boot from that for some reason any help?
  3. Member romanstopme's Avatar
    Mar 2008
    could the hard drive be broken?
    Feb 2009
    Remove the battery to clear cmos, this should give you a default BIOS
    ocgw
    peace
    i7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
    https://forum.videohelp.com/topic368691.html
  5. Member romanstopme's Avatar
    Mar 2008
    no it didn't work could this be because its a dvd not a cd i checked the dvd on a different pc and it works there
    Oct 2005
    666th portal
    have you tried a linux bootable cd to see if the drive will read/boot a cd? might be a picky drive.
  7. Member romanstopme's Avatar
    Mar 2008
    thanks never mind i got the pc to turn on in safe mode but still having problems with booting from the dvd to reinstall everything
  8. Member romanstopme's Avatar
    Mar 2008
    how do i do that? download a linux bootable cd?
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    most linux distros are bootable/runnable off the iso. knoppix, ubuntu, etc... you download the iso, burn to cd, and instead of install, choose run from cd.
  10. Member romanstopme's Avatar
    Mar 2008
    how would i make something boot of a flash drive or hard drive?
  11. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    some newer motherboards will allow booting off a flash drive, go into the bios and see if usb device is listed in the boot order. hard drive booting? do you mean a usb connected hard drive? might work if the bios allowed it to be selected, and the drive had an os installed already.
  12. Member romanstopme's Avatar
    Mar 2008
    my problem is i put the xp home edition on a dvd instead of cd and that's why it wouldn't want to read it thanks for ur help.
