Yes, another one of these threads.... MKV failing to do its job....
Any tips? Using MKVmerge GUI.
Results 1 to 10 of 10
tnx, ill give that a shot.... Weird how MKV fails mux file formats that are a decade old (wav) or newer ones (OGG).
Problem right now that, is one of the programs I downloaded to convert it into ac3 before ended up screwing my computer. Now I cant play any mkv unless its in VLC or MPCHC.
O well, ill be formating soon anyway... -
What's the problem with mkvmerge? What happens when you drag the vorbis file to the MKVmergeGUI window?
Why? Is there something wrong with XviD in MKV?Originally Posted by johns0 -
The op was having problems muxing the avi with ogg but i just thought of an easier way is to load the avi into virtualdub and save the avi with the ac3 leaving the ogg out and mux to mkv with mkvmerge,if mkvmerge still doesnt want to accept the avi with ac3 then re-encoding is needed.Originally Posted by creamyhorrorI think,therefore i am a hamster.
its not an AVI, its an MKV with a audio track.... I simple want to add another.
Havent tested that program yet, turns out MPC cant even run AVI...
AVI = MPC crashes
MKV = Never starts.
This stuff makes me SICK TO MY STOMACH.
If I 1 trillion dollars in the bank (richer then bill gates) and I downloaded a program, installed it, then went to run it and the program said "only converts 80%, need to pay 5$ for the full version". I would not give them the 5$ out of principle.
It REALLY pisses me off that I wasted like 1 hour on this yesterday, and what did I get out of it? Lots of stupid programs who trick me into download it then wanting money.... And after all that? Well, I cant play damn video files. -
I was posting the response to creamyhorror as to what you should if your file was avi and what you should with the avi,since we know its already mkv do you have the codecs installed such as haali media splitter and ffdshow?
Sounds like that program you downloaded screwed your system. What was it called, so we know what to avoid?Originally Posted by SignedupGuest
Any one or more of your MPC-HC, splitters, or codecs are screwed. Uninstall that program you downloaded. Reinstall MPC-HC and Haali's Media Splitter. If that doesn't work, uninstall whatever codec pack you use (if you use any - if not, uninstall the individual codecs themselves), then install the codecs you need to use.
MKVmergeGUI normally has no trouble importing OGG audio, so it's probably something wrong with your system. -
I ended up formatting 2-3 days ago. Not sure what program caused the issue, im worried if I mention them all they would simple get more hits
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 01:45 -
ogg in mkv with AVIDEMUX
By Kurgan71 in forum Video ConversionReplies: 4Last Post: 23rd Apr 2009, 04:51 -
Ogg to Ac3?
By t_jay17 in forum AudioReplies: 3Last Post: 13th Jun 2007, 10:55
