hello everybody!
i'm moving my first steps in learning about video editing and such things....so please be kind :P....i'd like to know, i have a computer with just a vga connector, can i buy one of those vga-to-svideo cables for my tv? because i really think they cant work!... i mean one of these http://www.cpexol.com/images/caa007.jpg
thanks in advance![]()
Welcome to our forums. You are correct. That adapter won't work.
Newer computers, especially laptops, often lack S-Video ports, and every few months people ask about these devices. There are several existing threads on the subject. Here is one example: https://forum.videohelp.com/topic345015.html
There is a Google site search in the top right-hand corner of VideoHelp pages. Few subjects have not come up before, and using the Google site search may save you the trouble of asking a question. -
ok thanks for the answer
..mm... i cant use that damn cable, so just a few videocards can handle that kind of cable? the fact is that im going to buy a new video card for my desktop pc, a simple low profile video card, so since my tv is only capable of s-video and rca connections i think my only option is to buy a video card with s-video right?
Buying a new video card with S-Video out is your best option for picture quality .
The only other option, a scan converter (connected between your existing VGA port and the TV), would not give a picture that was of comparable quality. A scan converter would also likely be more expensive than many of the video cards that could provide a TV-out port compatible with your TV. -
ok grazie
and last thing....can i buy a video card with an hdmi connector and then find "something" to link it with my tv? probably no since hdmi is only digital....
I think a video card with HDMI-out but not S-Video-out would only be useful to you if you had a TV with HDMI connections.
I have seen converters for sale that have HDMI-in and component-out (for use with HDTVs that don't have a HDMI connection) or S-Video-out and composite-out, but they are not cheap (about $200 US or more). I wouldn't buy one in your position.
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 09:31 -
Electrical arc when plugging a VGA cable to a video projector into a laptop
By ggarland in forum Newbie / General discussionsReplies: 8Last Post: 20th Mar 2011, 21:17 -
VGA to DVI cable?
By mr-scarface in forum Newbie / General discussionsReplies: 8Last Post: 11th Mar 2011, 17:39 -
cant play video from laptop to tv via vga cable
By gismo694me in forum DVB / IPTVReplies: 2Last Post: 19th Nov 2010, 16:14 -
cable: vga to s-video
By themaster1 in forum ComputerReplies: 7Last Post: 16th May 2008, 18:25
