  1. While using Handbrake, it's possible to encode a file so that it will play on both iPods and mobiles which support H.264, and also PSP's. This was done by selecting the "PSP" preset and checking the "iPod 5G support" box, so the same file could be played without requiring a new encode for each platform.
    How would I do this with XviD4PSP?
  2. Bump, any ideas anyone?
    I don't you can check two profiles in xvid4psp so you have to adjust the settings manually, but I guess they are pretty similar for both the ipod and psp. Just manually check all settings in handbrake and then try use same in xvid4psp? And TRY TRY TRY.
