HI.
tnx for your help
i want to know how i can change the button screen of a motion menu.
infact i wand split a dvd 9 and i want delte command and TXT of button.
that is very simple in still menu
change the bmp with edited bmp (photoshop)
and delete the command is easy (PgcEdit)
but how i can delete the txt of button when the menu is motion.
i want after delete the command of button with PgcEdit ,delete the txt of button and keep the motion menu.
is it possible?
tnx guys
If the buttons are part of the movie then you have to demux the video, process it, and then put it back. It can be done, but it is a lot of work.
If, on the otherhand, it is just sub-pictures overlaid on the video during authoring, you should be able to remove them with little fuss.Read my blog here.
I don`t know what is your mean exactly.
but just i can tell you the movie is in backgrround and the txt is like subtitle (something like this) and there is no any motion in button (just high light effect)
the TXTs are like transparent that a movie is play in background.
Now plz tell me what can i do?
Play the menu VOB in a player - not as a DVD, but as a file. Or open it in VDub(Mod). If you see the text then it's encoded as part of the video. Removing it will mean using a logo remover and you'll wind up with a big blurry mess. Either that or cover it up using video or a still from a different part of the menu (if there's any available that won't look too out of place). You may be better off leaving it in and just doing what you usually do. For this kind of thing I use AviSynth and its Overlay command to replace text with moving video or with a still from a different part of the menu.
If it's really just a sub picture you see, and it's not encoded as part of the menu video, then you edit the BMP. Extract it from the menu (DVDSubEdit), edit it to get rid of the unwanted text (you said you use Photoshop), and then replace it (DVDSubEdit again). And get rid of the button(s) (PGCEdit). -
tnx guys for your help.
after play the VOB menu i can see the txt.
and this means the txt is combine to the video.
i think it is better i leave it here and just delete the button.
or maybe change the motion menu with a still .
anyway.tnx for your help and attention
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
DVDlab PRO : Motion menu, cells, missing button highlights !
By TheCap in forum Authoring (DVD)Replies: 18Last Post: 13th Jul 2011, 12:14 -
DvdAuthorGui menu Button
By sambat in forum Authoring (DVD)Replies: 7Last Post: 15th Mar 2010, 08:04 -
DVDAuthorGUI, menu button problem
By Pii in forum Authoring (DVD)Replies: 3Last Post: 5th Nov 2008, 06:14 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01
