When I convert a wav file (stereo, 48000 Hz, 16 bit) to ac3 (stereo, 48000 Hz, 192 kbps) I can hear a significant loss in stereo effect.
The ac3 sounds more "narrow" and "dull" compared to the original.
I have used eac3to and besweet for ac3 encoding, both with the same result.
When I convert the wav to mp3 @ 192 kpbs (using CDex), there is no loss of stereo effect and it sounds as perfect as the original.
Can someone tell me if I am doing something wrong here or if this is a known limitation of ac3?
Results 1 to 9 of 9
Driber.net webmaster
I used AftenGUI. The only setting I changed was the bitrate, I've set it to 192.
Driber.net webmaster -
download EncWAVtoAC3-4.1 with Aften R832 here: http://rapidshare.com/files/276363037/EncWAVtoAC3-4.1_Af_R832.rar.
just unrar and run...
important:
adjust Maximum Bandwidth 50, load your source, adjust bitrate to 192 and tell us about the quality of the result. -
ok, thanks everyone for your posts, I have figured out what the problem is
the ac3 is just fine after all, it was the player that made it sound mono: Media Player Classic
when I first encountered this problem, I though that it could be the fault of the player, so I played the ac3 in a different player and it sounded exactly the same: mono-ish
but just now I downloaded yet another player and the ac3 sounded perfectly stereo, so the conclusion must be that the players I tried so far are to blame
I went into the options of MPC, then to Internal Filters and checked the box "AC3" under "Transform Filters", restarted MPC and voila, the ac3 sounds way better
it's mind boggling that the default settings of MPC makes the audio sound inferior
It's not a good source, it's an old home video, so 192 kbps will be more than enough. I hear no difference between the ac3 and the wav source on quality headphones, so it's surely not going to make any difference hearing the audio on a TV.
But thank you for your input
Are there any tutorials to convert stereo MP3 to stereo AC3?
By rocky12 in forum AudioReplies: 10Last Post: 4th Sep 2011, 19:05 -
Stereo Mix - is there no sound quality loss ?
By Bansaw in forum AudioReplies: 2Last Post: 30th Apr 2011, 11:22 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 22:45 -
Converting WAV to AC3 - sound loss
By MackemX in forum AudioReplies: 10Last Post: 19th Mar 2009, 15:15 -
Hiss removal from AC3 file without converting it to WAV?
By Turbo Sensonic in forum AudioReplies: 21Last Post: 7th Jul 2007, 06:18
