I have Firefox 2.0.0.20 and now suddenly when I go to a URL that ends in mp3, like for example
http://www.fileden.com/files/2006/11/30/441298/unique.mp3
instead of going to the download dialogue box, now Quicktime pops up and tries to play the mp3.
I want to restore the old behaviour so that just the download dialogue box appears. I don't like when an application like Quicktime changes the settings on my computer without my permission.
I couldn't find anything in the Firefox settings that would solve this problem.
In Firefox: Tools -> Options -> Applications
You can always right click on the link and select Save Link As.
The best thing to do is not install Quicktime. -
Are you running win98 or windows me? If not you you really should update to at least firefox 3
Donadagohvi (Cherokee for "Until we meet again") -
You should also go into the Quicktime Control Panel applet, look for the Mime Types button/section, and disable the entries for the file types you don't want Quicktime to load (like MP3).
If cameras add ten pounds, why would people want to eat them? -
I'm running xp. This is a little bit like getting rid of a roach infestation. I tried the various suggestions given, which did not work for my version of Firefox. Then I went to Add/remove programs and chose complete removal of Quicktime, and that seemed to do the trick. Now, when I click on the mp3 link, the download dialogue box pops up.
I never knowingly installed Quicktime. It must be some kind of adware/malware that installed itself. -
Have you installed any other Apple program, like iTunes, or Safari? I'm not sure if there are any encoders/conversion software out there that forces a download/install of Quicktime...
jagabo's suggestion should have worked, if you changed the action for .mp3 files (or added one). Changing the MIME types would have helped to keep the browsers from directing that filetype to Quicktime, in addition.
Instant play of Quicktime movies no longer work with Firefox 4.x
By jbaugh in forum MacReplies: 4Last Post: 28th May 2011, 04:39 -
Newbie question. Have blu ray image, need to convert to quicktime
By apollo1980 in forum Authoring (Blu-ray)Replies: 18Last Post: 29th Dec 2010, 21:25 -
Firefox question - extension for scrolling URL window?
By Hank Kinsley in forum Off topicReplies: 1Last Post: 2nd Oct 2009, 07:34 -
avi dvix, mpeg quicktime dvd quality question
By minmin2003 in forum Newbie / General discussionsReplies: 2Last Post: 26th Aug 2007, 12:16 -
quicktime codec question
By Shaorin in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2007, 05:29
