Hi ppl,
I need help converting some dvd's. I have a bunch of dvd's which has been converted using an LG combo recorder (VHS and DVD). Old VHS tapes has been played and recorded onto the dvd on the same unit. Now I can play these dvd's in LG dvd players, but I cant watch them on other dvd players, my pc also just sees the dvd's as blank cd's.
Is there somehow a way that I can get software or codec to be able to view these discs, so that I can convert them to standard dvd format?
Any help would be highly appreciated.
Hi hech54,
thanks for the reply. Is there no way to play the disc without finalising them? I dont have the combo drive with me.
Thanks -
I've heard DVDDecrypter can finalize discs but I cannot verify that. Without that disc finalized you can get the data from the disc but it is NOT easy and probably not free. Look into ISOBuster and CDRoller for data recovery from discs.
Thanks for leading me in the right direction. I used Nero 8 express to finalise my disc.. just started a dvd session then went to disc info and completed the session.. It now works..
Now for stage 2, i want to rip these videos onto my pc to do some filtering on them as they are currently directly recorded from the vhs tapes.
What software DVD player most closely mimics a tabletop player?
By sdsumike619 in forum Software PlayingReplies: 1Last Post: 16th Sep 2010, 16:08 -
Use a software codec when capturing with an ADVC300?
By timothyd_1975 in forum Capturing and VCRReplies: 22Last Post: 15th Jun 2009, 23:06 -
player does not support the codec???
By angrymike in forum Capturing and VCRReplies: 12Last Post: 28th Sep 2008, 09:14 -
Which DV codec does capture software select?
By hollowman in forum Capturing and VCRReplies: 21Last Post: 24th Aug 2008, 13:53 -
Any software exist to determine required Codec?
By plemal in forum Newbie / General discussionsReplies: 3Last Post: 11th Mar 2008, 17:20
