I can't tell if this is a Bad Pal (25)to NTSC(29.97) conversion (interlaced).
Or some funky Film Hybrid,
AutoGK says the clip is FILM.
But playback seems jerky and when using Assumefps (25) I get blended frames.
Can someone please help and post their script so I can figure this out.
Thanks in advance.
http://www.mediafire.com/?sharekey=2293c475ea178c8841446e35a78dc463e04e75f6e8ebb871
Results 1 to 13 of 13
I'll try it, but does that panning scene look any different.
Thanks for your help -
It still looks jumpy to me.
Good job getting rid of the interlacing though. -
poisondeathray is correct; it just needs a standard IVTC.
No, you don't - not if applying it after an IVTC. Maybe you're thinking of ConvertFPS(25). AssumeFPS(25) just speeds it up....and when using Assumefps (25) I get blended frames -
There's still some issues using this script.
I noticed playing it back with virtualdub that the frame rate seemed fine.
I'm importing this into Tmpgenc and it plays back jumpy.
That's not the real problem I can use something else to re-encode it.
Try using that script using this sample here.
It gets all jagged and crazy during this scene.
(FILE is SAMPLE.VOB)
http://www.mediafire.com/?sharekey=edb7a9bee14c9aea1bee9a6e9edd9c76e04e75f6e8ebb871 -
It's Sample.vob.
http://www.mediafire.com/?kfywzz0zmoo
That's the part that gets crazy witht he script used above.
ANy idea what else would work so it doesn't get like that. -
Are you talking about previewing within those programs? Don't count on previewing to play smoothly in any editor. Editors are generally not designed as media players. And when filtering like this the CPU may not always be able to deliver the frames fast enough to get smooth playback. All that matters is how the finished product plays.Originally Posted by pureimpure
TFM().TDecimate() delivered smooth results with both VirtualDub and TMPGEnc Plus (23.976 fps with pulldown flags). Why the talk of 25 fps? Are you making a PAL DVD for some reason?
http://www.mediafire.com/?sharekey=edb7a9bee14c9aead9d5c56d04dfa8b089f6be9e8c2d2560c95965eaa7bc68bc -
Stupid Mediafire.
Here's Sample.vob (correct link)
I thought maybe it was a PAL to NTSC conversion. -
Are you talking about the moire artifacts in the windows? Unfortunately, TFM() has problems with that type of source. A manual IVTC will work:
xvid.aviCode:MPEG2Source("sample.d2v") AssumeTFF() SeparateFields() SelectEvery(10, 0,1, 2,3,5,6,8,9) Weave()
That probably won't work over the entire movie because there are likely to be breaks in the telecine pattern now and then. -
The problem is mostly (but not entirely) that those thin horizontal lines of the blinds are seen as residual interlacing by TFM, and the deinterlacer kicks in. It'll do a much better job (but still not perfect) by either raising the CThresh or (better) turning off the postprocessor:
TFM(PP=0)
TDecimate()
Interestingly, Decomb does a much better (and nearly perfect) job on that passage, also with the postprocessor turned off:
AssumeTFF()
Telecide(Guide=1,Post=0)
Decimate()
Or, you can leave the postprocessor on but tweak the VThresh so it's not as sensitive. Raising it to 70 from the default 50 seems to do the trick:
AssumeTFF()
Telecide(Guide=1,VThresh=70)
Decimate()
1080i HDTV captures and avisynth deinterlace filters
By FTW in forum Video ConversionReplies: 3Last Post: 20th Aug 2010, 19:47 -
Which Avisynth deinterlace plugin provides the best result?
By Mdoodm1000 in forum Video ConversionReplies: 7Last Post: 21st Jun 2010, 18:41 -
Deinterlace?
By ZedsDead in forum Video ConversionReplies: 6Last Post: 14th Mar 2010, 23:21 -
what's the avisynth deinterlace alternative for ffdshow's ?
By cobalt in forum Newbie / General discussionsReplies: 12Last Post: 24th Sep 2009, 09:34 -
Alparysoft Deinterlace for AVISynth problem
By _migz_ in forum Video ConversionReplies: 5Last Post: 3rd Aug 2007, 07:54
