    Aug 2005
    London
    Ok, sorry for some basic questions but I've never set up a wireless network before, but I just got a laptop and I want't to set it up as it has wi-fi.
    I've got a cable modem. So Do I just buy any wireless router, plug the modem into the router and the router into my desktop pc? Does this mean that the signal is being passed stright through the modem>router and into my desktop so I don't lose any connection speed on my desktop?
    What kind of security measures should I look for with my router, should it have a built in firewall or anything else?
    Any specs I should look out for (such as amout of antennas)?
    I live in a pretty small house and just need to be able to use wi-fi downstairs from my setup (virtually directly below) and in the garden, no more than 30 feet away.
    Also heard about N routers and G+ routers but don't know the difference.
    Any help, much appreciated.
  2. From what I read, be prepared for most wireless routers to freeze/act up now and again.
    Just unplugging it and leaving for a few minutes then powering up usually solves it, or re booting the laptop I find works.
    I got one of these and set up was a breeze, get the most powerful one you can, this one is a fast as my wired pc's.
    http://www.broadbandstuff.co.uk/product_info.php?sku=Linksys_WRT160N_Wireless-N_Home_R...oducts_id=1486
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
  3. N is faster. Router and wireless receiver must match for best speed, an N router and G card will run at G speeds.
    Avoid any Plus or Turbo features, these are non-standard and may not work across different makers.
    Rebooting the router takes seconds, no need for any wait period.
    If your wireless network is running as fast as wired, something is seriously wrong or you are measuring speeds incorrectly. Wired connections significantly faster, especially with a Gigabit router. If adding more wired PC's, get the gigabit unit.
    All routers have password security for wireless, use it or share your internet and network with your neighbors.
    With a cable modem, you must disconnect all cables and wait a few minutes before connecting to a different piece of hardware. Speed should not change to PC.
  4. Member usta's Avatar
    Jun 2009
    Netherlands
    You will have to buy a router. Go for well known brands, such as Linksys, to avoid a frustration with connection, interface and documentation issues. Some of the routers offer easy setup feature, that guides you though the process.
    Perhaps, it is best to search internet for articles, like: "How to set up home wireless network?".
    Obtain the connection parameters of your cable modem (IP address, DNS server, etc...).
    Set correctly the mode of the Router: Access Point or Home gateway.
    Use for security WPA2 encryption if possible.
  5. Member blinky88's Avatar
    Mar 2004
    Australia
    Wireless .... make absolutely certain it is SECURED or you could be in for some nasty surprises.
  6. Member Seeker47's Avatar
    Jul 2005
    Yes. But what's the deal with print jobs going to wireless printers on the network ? How do you keep that stuff private and secured ? And if it's an All-in-One device, can copies or faxes or scans done just locally at the device get plucked out of the air by others ? Encryption for that ? (Proprietary biz should be able to be kept that way.)
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
  7. Wireless printers use the same security as that set up on the router.
    Jobs done at the device are never broadcast and so are quite secure.
  8. Member Seeker47's Avatar
    Jul 2005
    Glad to hear that !
