Ok this is what im trying to do , i have a HD PVR hauppauge , it will record to .ts .m2ts .mp4 , i want to take any of these formats , cut the end and the start off them and then still use the digital audio on it without losing quality.
Ive tried h264TScutter it appears to work but when i play the file back its out of sync badly, any help at all will be great, this should be really easy but for some reason im getting nowhere (2 days trying now)
cheers folks
Yeah, it appears it (h264tsCutter) works okay for some people, poorly for others. I had no sync problems myself when I tested it, just ugly cuts, with a few frames of noise inserted. [shrugs]
Anyway, I have a Hauppauge HD-PVR and use tsSniper to edit the transport streams. It's reasonably accurate and clean. No sync problems yet.
1) Make certain you have installed latest ffdshow and Haali media splitter. Probably best to configure ffmpeg-mt as the h264 decoder. It's multithreaded, works fine for me.
2) In tsSniper settings, change splitter from "automatic" (the default choice) to "Haali media splitter AR". I had the program crash on me occasionally until I changed that setting. Each time the error message pointed to the splitter.
See if the above solves your problems. Good luck.
[EDIT] You can choose the mode (cut or scene) by right-clicking the pane on the right side. Use the arrows on the ends of the timeline itself to back up or advance to the next I-frame, then use the in or out markers. It's not difficult to get the hang of.Pull! Bang! Darn!
Rebuilding a DVD9 to DVD5 keeping DTS intact
By zoomie in forum Newbie / General discussionsReplies: 13Last Post: 6th Jan 2011, 01:37 -
MKV to dvd while keeping the dts audio intact
By Loonatik in forum Authoring (DVD)Replies: 13Last Post: 30th Mar 2010, 11:41 -
What Laptop is adequate for editing with Hauppauge HD PVR?
By Quivox in forum Newbie / General discussionsReplies: 2Last Post: 9th Jan 2010, 18:26 -
VirtualDub + New Audio + Editing + Audio Intact?
By hech54 in forum EditingReplies: 6Last Post: 16th Aug 2007, 15:57 -
convert flac to mp3 while keeping all id tags intact
By lordhutt in forum ComputerReplies: 2Last Post: 13th Jul 2007, 23:56
