Thanks to some on this forum I have successfully created a dvd from avi. Now I have a new question that I tried the search feature for, couldn't find and answer...so...
Moving arms and legs leave ghosts or 'trails' similar to the old superman movies where Christopher Reeve would run, the camera would show a blur behind the actor, indicating speed. That's what's happening in a limited way on my project.
I hope I am making sense.
Is there a way of processing the video which will eliminate this distortion?
Trailing is a sign of overprocessing. Did you use noise reduction, time-based correction, or any other filtering in the process? If so, you need to tone it down until you get a happy medium between image enhancement and motion without so much trailing or image lag.
Maybe you can outline the process, software and settings used from AVI=>DVD
Did the original AVI have "ghosting?" -
Originally Posted by poisondeathray
Yes. It does. It's hard to tell on my 19" LCD monitor, but it is there.
So the problem is the means of capture?
I am going to experiment with Dscaler, my capture program of choice. I have just turned off 'sharpness', 'Judder Terminator' and 'Noise Reduction'.
Is there something else I should look at?
Thank you for putting me in the right direction to correct this problem!
Twheels -
How can I tell what my input signal is, and how can I tell if there is a conflict?
You'd have to give more information: i.e. what are you capturing, how you have it set up etc...
e.g. if you captured an interlaced source , and the program applied blend deinterlacing, you would get ghosting
Blur/Trailing image after driver update
By carlos28355 in forum Media Center PC / MediaCentersReplies: 6Last Post: 3rd Sep 2011, 11:11 -
Encoding trailing effect PAL > NTSC
By KarenM in forum Authoring (DVD)Replies: 0Last Post: 10th Jul 2010, 13:04 -
DVD Flick created image distortion
By Vianty in forum Authoring (DVD)Replies: 7Last Post: 28th May 2009, 02:17 -
trailing effect on dvd
By D_Shives in forum Authoring (DVD)Replies: 12Last Post: 30th Jun 2008, 07:42 -
What kind of distortion is this and how do I fix it? Image inside.
By sithguy in forum RestorationReplies: 13Last Post: 12th Jan 2008, 21:07
