Hello
I wonder if it is possible to convert a AC3 file that is PAL to a AC3 file that is NTSC?
I have the *.ac3 file and the video that i have is a ntsc and just wanted to add a second audio to it and when the audio is PAL the sync is out of order.
Thanks for the help
Hey,
Yes, it is possible, if you extract the AC3 to WAVs, then do a slowdown with an audio editor, and re-encode to a new AC3. But it seems you've taken your AC3 file and your video file from different sources, right? In this case, they probably won't be in sync even after conversion. Don't bother doing the conversion unless you're prepared to do further work on your audio track. -
If they are from the same source (e.g. PAL vs. NTSC version of a studio movie) , and the same theatrical cut (not a different version of the movie or "director's cut" etc...) you can try eac3to. There is a GUI for it, but it's actually harder to use than the command line
eac3to input.ac3 output.ac3 -slowdown -
thanks people... did use eac3to and then VirtualDubMod to join the file, but it was stil 3sec out of sync but VDM did fix it for me.
Thanks alot for the help
Convert NTSC AC3 (29.970) To PAL
By DeathStalker77 in forum AudioReplies: 0Last Post: 26th Apr 2010, 22:09 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 08:06
