Hi, I have a video and I think I need to deinterlace it with some option selected that I don't know about. The problem is when the character walks it looks like a blur. The video is as follows:
http://www.mediafire.com/?ty2mzyw2ygz
Eventually I got rid of the blur, but the video was all grainy. I selected smart deinterlace and I selected options Frame-and-Field Differencing, Edge-directed interpolate, Compare color channels, motion map denoising, motion threshold - 15, scene change threshold - 100, Field swap before phase shift, Phase shift, and Field swap after phase shift. I tried to mix and match but with no results. Here is the file I ended up with, as I said earlier, the walking is fine but the video is grainy.
http://www.mediafire.com/?znybdnyzkyz
Thanks.
Results 1 to 10 of 10
Why are you using Field Swap? That is a workaround for capture devices that save the scan lines in the wrong order. It has screwed up your video. Field swap swaps pairs of scan lines. So if scanlines are numbered (from the top):
0, 1, 2, 3, 4, 5, 6, 7...
after Field Swap they will be ordered:
1, 0, 3, 2, 5, 4, 7, 6...
This is what's causing the jagged edges you see. (You can also view this as shifting the top field down one scanline and the bottom field up on scanline.)
Your first video isn't interlaced. It appears to have had a severe temporal smoother applied. There is no way to fix it. -
Thanks for the quick response. Can the original .TS file from my capture card be fixed?
I ripped the same clip from the original .TS file, the only thing that has been done to it is it was cut with h264 cutter or whatever it's called.
http://www.mediafire.com/?zaownznmdki
Thanks again. -
Unfortunately, the temporal blurring is already present in the TS file. If you run a simple Bob Doubler (displays one field at a time) you'll see that every field looks like a triple or quadruple exposure.
Any reason why that happens, it is recorded straight from my PS2 with component connectors. Any idea how to prevent this? Maybe a new program, I am using Arcsoft TotalMedia Extreme as that came with my Hauppauge HD-PVR 1212. Or should I post this in the Capturing section?
it seems to be one of the weird avchd types that is 60i internally and the file header says 30i and plays at 30i.
this was the best i could come up with. the weirdness around the moving character appears to be part of how the game renders movement.
ts_cut_rendered_in%20vegas_pro9.mp4--
hurray for programs working together
thanks for your help, it is much appreciated. -
A simple discard field and resize in VirtualDub looks about the same as the Vegas clip.
HD footage has excessive motion blur.
By mattlolwtf in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 5th Apr 2009, 23:05 -
AVCHD - motion blur problem
By Coroner in forum Newbie / General discussionsReplies: 4Last Post: 8th Dec 2008, 16:59 -
motion blur on tv
By ineedhelp007 in forum Newbie / General discussionsReplies: 3Last Post: 18th Dec 2007, 10:49 -
Motion type blur in premiere
By PharmBoy in forum EditingReplies: 0Last Post: 11th Jul 2007, 19:03 -
> Interlaced and motion blur <
By Dark Alpha in forum Newbie / General discussionsReplies: 53Last Post: 12th May 2007, 16:08
