Greetings. This is my first time that I'm buying a HDTV, & I'm thinking about buying one for games, as well as Blu-Ray movies & for watching TV. I went on Amazon, & I came across where there are some HDTV's that are in 1080p & that are in 240 Hz. I found one of them here:
Samsung LN40B750 40-Inch 1080p 240Hz LCD HDTV with Charcoal Grey Touch of Color.
Should I go for it? Help would be appreciated. Thanks!
240 Hz - marketing gimmick really
led samsungs are pretty nice for the most part, other models i would stay away from .....
i would get a panasonic lcd - and never mind about the specs - though get one with 1080p native , 120hz or 240hz or none - doesnt really mater
for gaming you would want fast refresh (240hz is not the refresh rate)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
yeah I wonder what you would really gain from the 240hz..although we supposedly can't detect anything over 60hz, I suppose I understand the 120hz pitch since it is a nice even multiple of 24 and 30, but anything else as I understand it would be indistinguishable.
Thanks a lot, guys. You have been very helpful! I'm now considering setting my eyes on this TV here:
Samsung UN40B7000 40-Inch 1080p 120Hz LED HDTV.
I now see what you're saying, as I probably won't be able to tell a difference between 120Hz & 240 Hz. Again, thanks.
the samsung 7000 series looks good - on really white scenes you will notice some dark areas in the corners - but not noticeable usually
I saw panasonic bragging about 600hz in an ad.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
The 240hz set I saw, a Toshiba, actually looked worse than a 60hz set.
toshiba has gone down in quality (picture and build) so much lately it is an embarrassment to toshiba
i personally do not like 240 - it looks artificial"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
720p or 1080p HDTV - Help
By GerryR in forum DVB / IPTVReplies: 4Last Post: 21st Mar 2010, 21:08 -
42inch 2ms, 1080P FULL HDTV Settings Question
By BenjaWiz in forum Newbie / General discussionsReplies: 11Last Post: 24th Oct 2009, 23:35 -
LCD HDTV 1080p with HD tuner.. grainy!
By Browncoat in forum DVB / IPTVReplies: 5Last Post: 21st Dec 2008, 21:06 -
1080p hdtv rips?
By jbaruch76 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Dec 2008, 02:12 -
If I don't have 1080p HDTV, it's pointless to buy an HDDVD/Blue-Ray, right?
By the_importer in forum DVB / IPTVReplies: 37Last Post: 19th Sep 2007, 16:40
