I'm using MPC HC 32bit on XP 64.
It's works fine because I installed a package from Codecguide.
Recentely a new MPC HC x64 was released but it's plays only avi files.
Could someone help me to understand what is the correct way to get my MPCHCX64 working "at best"?
TIA
PS even a a link to a guide on movie playback will be appreciated.
You shouldn't need any codec packs for mpchc, just enable all the filters under view->options->internal filters in mpchc. And if you want it as default players for all video extensions change it under options->player->formats.
And use the official mpchc 64bit from http://sourceforge.net/projects/mpc-hc/files/MPC%20HomeCinema%20-%20x64/MPC-HC%20v1.3.1249.0_64%20bits/MPC-Homecinema.1.3.1249.0.(x64).zip/download -
I did it, even If I don't understand the difference between "Internal" and "stand alone" filters.
I even don't undertand why these internal filters are not selected by default......
I still have problem with VC-1 (WMV3) file (Info from mediainfo x64) -> error is "cannot render the file"
moreover, playing MPEG file MPC HC X64 crashes.
Any suggestion?
thank you
Cyberlink filters for playback in MPC - not working
By menkatek in forum Newbie / General discussionsReplies: 1Last Post: 6th Apr 2011, 05:13 -
Cannot install lame mp3 on vista x64
By jarko in forum AudioReplies: 14Last Post: 28th Apr 2010, 04:12 -
MPC HC x64 double images/videos since svn 1503? (pix attached)
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 21st Jan 2010, 08:30 -
VirtualDub x64 with ffdshow vfw x64 no H264
By SandyB in forum Newbie / General discussionsReplies: 8Last Post: 10th Aug 2009, 18:45 -
MPC Filters (ffdshow, coreAVC)
By blueninja in forum Software PlayingReplies: 2Last Post: 11th Jan 2008, 08:43
