I'm about to rip 1000s of hours of VHS tapes to digital format.. I'm going use a Panasonic AG-1980P -> Canon DV cam -> Ubuntu (dvgrab) -> AVIDEMUX..
I'm going to use AVIDEMUX to do bulk editing and some processing (noise cleanup, deinterlacing, DIVX conversion, etc)..
Here is my question: Is that the best tool? I've been using it for a while and I really like it, even more than VirtualDub.. I just don't see a lot of people raving about it so I'm 2nd guessing my choice now.
Best for in terms of what?
If you like it and it does everything you need, then that's all that matters
I think it's a great tool, and you don't have much choice if you are on linux. If you have access to windoze, Vdub may has more available plugins but you might not need them for what you are doing. Both can make use of avisynth, but it's a bit easier with vdub. -
Originally Posted by poisondeathray
I'm going to use it for basic / bulk editing of raw DV files and them some simple processing.. Deinterlacing is the processing I'm most concerned about.
Avidemux - Why is there pixelation from stream movie?
By Jmart285 in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2012, 10:20 -
Loss of Audio Sync after cutting (Avidemux)
By Maverick-X in forum EditingReplies: 4Last Post: 14th Oct 2011, 15:12 -
Audio out of sync after cutting scenes from an MKV file with Avidemux
By kr1ge in forum EditingReplies: 1Last Post: 23rd Oct 2010, 14:08 -
AVIDemux 2.4.1 cutting audio or maybe video sync issue
By ColdFusion2 in forum LinuxReplies: 9Last Post: 11th Sep 2008, 10:27 -
Anyone doing Straight D-VHS to H.264 Capture + Post Editing / Cleanup?
By bradeso in forum RestorationReplies: 4Last Post: 22nd Apr 2008, 03:01
