I just installed the latest Nero and now I get an error at the end of CD burns, whether they're VCDs or data CDs. It doesn't matter. I get
"Could not perform end of Disc At Once
Burn process failed at"
It says I have a Matshita CD-RW CV-7585. The previous version of Nero didn't have a problem. I'd prefer to use the new Nero and not have to go back to the older one, because the newest Nero supports bin and cue files.
Is anyone else having this same problem, and do you have a solution and/or a work-around?
Results 1 to 11 of 11
Does it also happen if you try doing simulation burn ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
I have the same problem and made a topic about it also.
My problem is with DVD-RW and also in simulation. -
I've had the same problem with the last two versions, I'm currently using Vers 5.5.5.1 without any problems. If I get time in the next week I'll play around with the latest version and post another reply if I find anything.
Are you guys using the v5.572 ? (I think I heard of a 5.573 out, but not sure)
Best Regards,
Sefy Levy,
Do you both have the same CDRW drive ? if not, do you use the latest firmware for your CDRW ?
Best Regards,
Sefy Levy,
I havn't had this problem everytime but I have had it on occaision however, all my vcd's have been fine with or without the reported error.
My CD-RW works ok but my Pioneer A03 doesn't..
I'm waiting for the region free firmware before updating. -
I downloaded the latest firmware from Nero, but that doesn't appear to improve things.
Burning DVD Could not perform end of disk-at-once
By jasonkral in forum Authoring (DVD)Replies: 8Last Post: 13th Feb 2011, 23:05 -
Could not perform end of Disc-at-once
By smt16 in forum DVD RippingReplies: 1Last Post: 18th Jun 2010, 05:50 -
Could not perform end of disc-at-once on dual layer dvd only
By Subhash in forum DVD & Blu-ray WritersReplies: 20Last Post: 25th May 2009, 13:09 -
By mrjoetoff in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2008, 13:27 -
Error: Could not perform end of Disc-at-once - Please Help
By patrickj0781 in forum ComputerReplies: 7Last Post: 20th Jun 2007, 19:28
