Hello everyone,
I'm new here, however I don't exactly consider myself a 'newbie', at least when it comes to amateur video creation.![]()
Anyway, for about four years I've been messing around with cameras and video editing, and I've finally decided to make the switch to High-Definition. I have a film planned out that I want to film next summer with my friends, and I want to use the best audio equipment that I can.
I've found that a person can make their own boom mic for less than $50 (plus the cost of the actual shotgun mic) and I plan to do this; however I have a few questions on extension wires. This is the mic I plan on using (http://www.bhphotovideo.com/c/product/444022-REG/Azden_SMX_10_SMX_10_Stereo_Microphone.html), and this is the extension wire I'll need (http://www.amazon.com/3-5mm-Stereo-Headphone-Extension-Straight/dp/B0002KR13M). Do any of you recommend those two purchases, or should I look for something better?
I'm not from the UK, but this is the video I found that taught how to create a boom pole for cheap (http://www.youtube.com/watch?v=xr3uqfvQblA&feature=related). I really like that guy!
Thanks to all who provide advice!
-JEL Productions
I changed the subject so it actually says something about your topic. You can adjust it by clicking on the edit-button.
Thanks! Sorry I didn't think about that...I'll be sure to name a topic appropriately next time.
-JEL Productions -
Search around there are many forums dedicated to what you are doing with lot's of discussions and tips.
http://www.filmmaking.net/fnetforum/
http://www.indietalk.com/ -
"Quality is cool, but don't forget... Content is King!"
Basic answer, high impedance is good for a few feet. Longer cables will generate noise.
Pro mics operate at low impedance and require a transformer for interface with a consumer camcorder. Low impedance mics can use long cables. Some prosumer camcorders have low impedance 600 ohm mic/line inputs.
Low impedance balancesd XLR cables and connectors are typical for anything over about 5 feet. A popular mic mixer for camcorders is the Beachtek.
http://www.dvcreators.net/beachtek-xlr-adapters/
A simple mono 600 ohm mic can be interfaced with this Shure transformer.
http://www.microphonesolutions.com/a96f.html?productid=a96f&channelid=PGRABRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Using wireless mic with shotgun mic on Canon HF G10
By jimleben in forum AudioReplies: 5Last Post: 23rd Jan 2012, 21:11 -
LG HT 305SU (MIC IN / MIC OUT Problem)
By iamjamal in forum DVD & Blu-ray PlayersReplies: 0Last Post: 25th May 2011, 17:38 -
Where can I find out how to connect all these wires?
By sarainelkins in forum AudioReplies: 1Last Post: 15th Apr 2008, 02:01 -
Wires in the wall
By ahhaa in forum ComputerReplies: 6Last Post: 12th Mar 2008, 13:13 -
Is it possible to record tv show via wires with a laptop?
By whatever911 in forum Capturing and VCRReplies: 4Last Post: 14th Sep 2007, 17:28
