I would like to encode VC-1 to Mpeg2 (recently I use to encode H.264 to Mpeg2 with Elecard converter Pro) But I cannot put the VC-1 file so does anyone can share me some software.. ??![]()
I guess elecard supports avisynth scripts so you can try install avisynth, make .avs text file with just
and then open the avs in elecard. You must also be able to play the vc-1 in windows media player.Code:directshowsource("c:\folder\video.vc1")
Need To Batch Encode 78 MPEG2 Files
By hech54 in forum Video ConversionReplies: 7Last Post: 31st Dec 2010, 07:10 -
How do i re-encode an MPEG2 file with mp3 audio?
By snafubaby in forum EditingReplies: 2Last Post: 10th Jan 2009, 18:56 -
Cut parts out of a mpeg2 without having to re-encode?
By ltd. in forum EditingReplies: 7Last Post: 23rd Dec 2008, 17:21 -
Better format to encode to: MPEG2 or DivX/AVI?
By Grunberg in forum Video ConversionReplies: 15Last Post: 15th Feb 2008, 08:29 -
I need to encode video to a 1280x720 mpeg2 at ~40mbit
By wldmn13 in forum Newbie / General discussionsReplies: 5Last Post: 18th May 2007, 16:19
