Hi all,
Like the subject line says, I searched, but the results didn't yield anything useful.
Here's what I did:
I took my 6 mono files and used Audition to create a 6 channel wave. I loaded my video into VirtualDub with no problems. I loaded my wave with no problems. I attempted to play the clip... problem...
I received the error "0xfffe" and was told that it didn't have the decompressor necessary to play the clip/audio.
I thought that it might be a problem with the fact that I was using a 6 channel wave. So, I created an AC3 with Soft Encode. I tried adding that "stream" in VirtualDubMod. Again, all seems fine until I try to play the clip. Then that damn error occurs.
I used GSpot and it told me what I had pretty much assumed: Codec NOT installed.
So, what codec do I need? Where do I download it? What should I do? What shouldn't I do? Etc., etc., etc.
Thanks for any help you can provide.
P.S. - Reading over my text, I see much of it comes off as flat out obnoxious. Sorry about that. It just happens when you're very frustrated![]()
Try using Virtualdub with the AC3 plugin to insert the 6 channel AC3 and direct stream copy the audio. Also install the AC3ACM decompressor as poisondeathray suggested.
Thanks for the replies. I'll install them and let you know of the results.
Okay... sorry for the delay in reply.
The recommendations you three made did work in VirtualDub and VirtualDubMod. Though I don't know which installation it was that made it work.
However (there's always a catch), when I converted the AVI to a VOB, in order to play it in WinDVD, the video was fine, but the audio was cringe-worthy.
It's difficult to describe what it sounds like. It's sort of a rapid, pulsing, white noise-like, static mess... without a single trace of the actual audio that should be playing.
Does anyone know what could be causing this/how to resolve it? I'm lost, since all other AC3s (contained in my DVDs) work just fine.
Thanks in advance for any help you can provide.
google search pages keeps erasing my search criteria -- [RESOLVED]
By vhelp in forum ComputerReplies: 0Last Post: 5th Mar 2011, 16:27 -
VirtualDub Error 'Says "Couldnt locate decompressor for format xvid"
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2010, 23:05 -
MJPG Decompressor
By Colton-Nan in forum Video ConversionReplies: 15Last Post: 25th Feb 2010, 10:27 -
Search Excel Spredsheet Data in Vista Search
By mn072065 in forum ComputerReplies: 11Last Post: 29th May 2009, 00:26 -
Question about search engines that search Rapidshare
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 9th Nov 2008, 03:08
