    Mar 2005
    I have a few movies that are around 4-5 GIGs each and contain a bunch of Video TS files. I know that these are meant to be burned onto DVD but I want to just make all these Video TS files into 1 basic AVI or MPeg file. Is it possible? If so what do you recommened is the best program that I use?
  2. aimersoft dvd ripper, add the Video_ts files and convert to avi, or use format factory and convert them to 2-pass h.264 avis and achieve half the size of the first option with same quality
    Mar 2005
    Im using FormatFactory and I dont know how to make the 4 Video Ts files into 1 AVI?
    Also I didnt understand what you meant by "convert them to 2-pass h.264 avis and achieve half the size of the first option with same quality" how do you do that and how can I convert a few of the video ts files into 1 avi?
    thanks for your help.
    Apr 2004
    Miskatonic U
    To get a standard mpeg-2 file use VOB2MPG. It wont make the files much smaller, but you will get the original video and audio out of the VOB format.
    Use AutoGK to convert to Divx/Xvid encoded AVI files. AVI.net is another easy to use option.
    Read my blog here.
    Mar 2005
    ok but how do i convert all them into 1 file? because there are about 4-5 video ts files each one of them is a part of the movie i think
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    They are VOB files, and they come from a DVD. They should also have an IFO file. Either load the IFO file or the first VOB file (numbered 01), and the rest will be included if necessary.
    Of course, there could be multiple movies inside a set of VOBs. If you are sure there is only one, load the IFO or first VOB file. If you think there are multiple videos (e.g. episodes of a series) then use DVD Shrink to split them up, then convert, or use VOB2MPG to extract all the titles, then convert each one.
    Read my blog here.
    Mar 2005
    Thanks GunSlinger your the man ill try it out!
