I have worked in v2.51 but it has a problem with subtitles that is very enoying. The subtitle is perfectly sync in Subtitle Workshop but then DVD-lab PRO v2.51 (Seems to be for all 2.x versions) has some sync problems and changes the time so some subtitle lines overlap. The correction feature in DVD-lab isn't an alternative for me. This is why I use v1.6.
1.6 looks almost identical to 2.51 so there isn't any problem there. Everything works great EXEPT that the Maps only color is black, and black only. Under the tab Color I can change the color of text but active links, Normal, Selected, Activated is black, black and black.
I have tested to open the .dal in 2.51 but still in black.
I have tested to create a .dal in 2.51 but 1.6 cant open it.
I have tested to export a menu in 2.51 and import in 1.6 but it still is black.
I have tested the above and compiled a DVD to see if it was a color bug, but the compiled version was also black.
Does anyone have a clue that the problem can be?
Or is their a way to export a generated subtitle from 1.6 and import it so 2.51 DONT generate a subtitle. Just like with export/import menus.
I reinstalled v1.6 and noticed something. I tested some in 1.6 and a new project have all the colors bit it can change to black only, and then I'm screwed. I don't know how it changes to black only or why.
It seems to be a bug in 1.6 but 2.x has the subtitle problem it isn't an alternative.
Now I know why to backup even after every single change.
This thread can be ignored.
"DVD Lab Pro"/DVD Authoring for Mac?
By Paker in forum MacReplies: 4Last Post: 8th Aug 2011, 02:50 -
DVD Lab Pro Error: "Read data size is over the buffer limit"
By Motinha in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2010, 03:49 -
DVD LAB PRO - color map
By blackmiles in forum Authoring (DVD)Replies: 5Last Post: 14th Apr 2010, 03:56 -
DVD Lab Pro - Three elemenetary "hot to ....." questions
By perfection in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 07:45 -
Any Program to "blank out" or "black out" a portion of
By mbextreme in forum EditingReplies: 6Last Post: 18th May 2007, 05:04
