I am trying to set up a Multi-menu DVD as follows:
1)Main- Play all, and Episode list buttons
2)Episode Selection- 6 episode buttons linking to scene selection
3)Scene selection screen..4 buttons for each episode.
What I want to happen is: Play All starts film1, and continues. Episode Select goes to the SubMenu. When an episode is slected, I want it to go to the scene selection. What is happening is: Play all starts film 1. Episode Select starts the selected episode...not goes to scene select.
I have modified the settings for the project each way possible, I have also checked and rechecked the coding for the buttons to be sure the direct to the correct point.
Any Suggestions for coding the buttons to get this to work the way I want?
I think I may have found an answer to my problem, but it involves editing the XML file created during the Create DVD Process. I am reading over the help pages now to try to understand what each command means.
But at this point, i'm still willing to accept all help i can get.
DA
EDIT: I have finally found the answer to my problem. I created the dvd every way I could, and copyed the xml file to notepad. I then compared the differences in each, with notes made for each setting change.
The fix--once I knew what I was looking at--is quite simple, and involved editing the Pre settings for the MainSubMenu1 (episode select screen). I simply had to set g1 to 0 so that the titleset#menu wasn't skipped. The play all button works as it is supposed to...skipping all menu screens from one episode to the next. In the words of London Tipton (Sweet Life of Zack and Cody--Disney show) YAY ME!!!
ps. excuse my cornyness, tis very late and i'm tired :P -
Congratulation for finding the solution yourself!
GUI for dvdauthor:
https://www.videohelp.com/~gfd/
GUI for DVD Author settings problem vista 32
By extent in forum Authoring (DVD)Replies: 5Last Post: 13th Nov 2011, 19:24 -
In GUI Dvd Author-my finished dvd has no sound on the menu in some players?
By extent in forum Authoring (DVD)Replies: 3Last Post: 2nd May 2009, 05:19 -
GUI DVD author : Show DVD problem
By Genevieve in forum Authoring (DVD)Replies: 4Last Post: 30th Apr 2009, 07:33 -
Question about error with Gui For DVD Author
By jimdagys in forum Authoring (DVD)Replies: 2Last Post: 27th Nov 2008, 07:38 -
DVD Author Gui
By Flying Doctor in forum Authoring (DVD)Replies: 4Last Post: 1st Aug 2007, 09:12
