Im using Msu logo remover but the output file is nearly 5gb and rising and Im not even half way through.
Any advise on how I can get the output file so its the same size as the input file which is only 700kb
Results 1 to 11 of 11
Choose a codec (XviD or DivX, most likely) and a bitrate, among other things. You're just making an uncompressed (or lossless) AVI file.Originally Posted by Rogert
700kb? Are you sure about that? -
Im sorry can you give me detail as to how I change the bit rate
https://forum.videohelp.com/topic244151.htmlOriginally Posted by Rogert
isnt there something I can set in Virtual Dub whilst using MSU logo remover that keeps the original AVI file size?
Set the video bitrate to same as the source bitrate. Get the source bitrate from video->information in virtualdub.
Rogert, what kind of AVI do you have? AVI is just a container for a wide variety of video codecs. If you want to maintain the same file size, figure out what kind of .avi you have (i.e. - DV, Divx, Xvid, Uncompressed, etc.) VirtualDub defaults to an uncompressed AVI, which makes a humongous file. Go under Video > Compression in VirtualDub to see the list of AVI choices, and select the one that best suits your needs.
To learn which AVI codec your source file is, download the free program GSpot from the Tools section of this site, and open your AVI in it. GSpot will tell you what codec, bitrate, frame rate, etc. your source file is.
Just a word of warning. If your source is Divx or Xvid and you want to encode back to that format, you will degrade the image quality to some extent, depending on the bitrate you select. -
No. You are changing the video by adding an overlay. You need to re-encode the video.Originally Posted by Rogert
The second you add a filter to that video all hopes of "direct stream copy" are gone. -
That doesn't mean you can't have the same file size.
As Baldrick said, just use the same bitrate as the original.
Using VirtualDub 1.10
By eteaneck in forum Newbie / General discussionsReplies: 3Last Post: 8th Mar 2011, 15:50 -
Why is Virtualdub doing this?
By skybooks in forum Video ConversionReplies: 4Last Post: 29th Jan 2011, 21:11 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
Help with VIRTUALDUB Please !!!!
By spliffy in forum RestorationReplies: 10Last Post: 30th Jun 2007, 08:28
