Any idea how much electricity a computer uses in a month?
Just heard a tech guy on talk radio claim he was running four servers at home. All were AMD and 24/7. He alleges when he switched to Intel cpus his power bill was reduced by $100 a month...
I find this very hard to believe...
Results 1 to 10 of 10
A quick google found this info....
http://maximumpcguides.com/windows-vista/how-much-electricity-does-my-computer-use/ -
Too vague to make any conclusions,
It depends what you are running. You can go anywhere from ~100-1000w per server for usage
e.g.
Was he running multiple GPU's concurrently? or headless?
What kinds of workloads? 24/7 doesn't necessarily mean 100% load? e.g. if they were web servers waiting idle for requests
How old were the AMD's? 140nm? 90nm chips? Then $100/month easy to believe
On larger farms 20-40% of the cost goes into cooling
Electricity costs vary a lot by region. I pay 8cents/kWh , some people pay 30. So if I saved $100 in a month, they would have saved $375
An easy way to determine usage is plug in a kill-a-watt meter to your computer. Many UPS's have LCD displays as well for usage -
I find most things on talk radio are hard to believe..... gave it up eons ago...Originally Posted by kenmo
Obvoiusly, you can't just switch CPUs. He switched CPUs, motherboad (and its various chipsets) and probably memory. Who knows what he did for drives, PSU, GPU (if any), NICs. If he'd swithed to the latest AMDs, he'd have found at least the same difference. Both AMD and Intel have step down technology to save power when the CPU isn't taxed.Originally Posted by kenmo
Buncha crap.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
You can switch just CPUs and it can make a large difference in power consumption. Going from 95W thermal spec chips down to their LV counterparts at 40W will be noticeable. Combine that with the fact that there are 2-4 of these chips in a single enclosure and there is some savings to be had.
I did a cost justification on something similar to this, I'll see if I can find some numbers on it. The big OEMs probably already have something to compare to.FB-DIMM are the real cause of global warming -
I have one of those Kill-a-Watt meters I can plug the computers into. My HTPC computer uses about 140W average. 3 watts when off. (The 5V rail running the RAM, LAN, etc. ) Start up is about 160W for ten seconds as the HDDs spin up and the optical drives check for discs.
I pay $0.12 per Kilowatt Hour, including taxes, other charges. 140W / 1000 = .14 KWH X 24 hours a day = 3.36 KWH per day, which would be $0.12 X 3.36KWH or $0.40 for 24 hrs or X 30 days = $12.00. That would assume 24/7 operation, but you could figure it out closer. Your electric bill should give your KWH rate. (Hopefully my math is right.
Sounds like a typical intel is better than amd fanboy with inflated stats.Originally Posted by kenmoI think,therefore i am a hamster.
No, it could very well be true, but I doubt we're hearing the entire story. If he was running Santa Anas or some of the recalled 252s prior to the switch and then changed to low-voltage Xeons there could easily be a reduction in power consumption, but it's hardly a fair comparison. The same could be said going to those LV Xeons from the older Noconas.Originally Posted by johns0
There are quite a few ways to reduce power consumption on server- and workstation-class gear compared to consumer desktops. Getting lower-voltage chips with lower thermal spec, getting a high-efficiency PSU, green HDDs and a controller that can spool them down, using speed-step technology to underclock your CPUs when they're idle, and of course just shutting off the computer work for consumer gear
How many hours a day do you spend on your computer on average?
By johns0 in forum PollsReplies: 13Last Post: 10th May 2011, 15:25 -
How to burn a dvd that an average computer user cant copy!!
By Imran87 in forum Newbie / General discussionsReplies: 35Last Post: 8th Jul 2010, 15:06 -
How I can reduce the time consumption?
By ramz in forum EditingReplies: 11Last Post: 7th Jun 2010, 11:42 -
Digital TV Set Power Consumption/Portability Question
By Frank-0-Video in forum DVB / IPTVReplies: 2Last Post: 2nd Feb 2009, 15:36 -
how to save electricity while downloading
By d_unbeliever in forum ComputerReplies: 9Last Post: 10th May 2008, 02:50
