  1. Member ks47's Avatar
    May 2007
    What is the script for loading a bunch of gifs in avisynth? Using ImageSource for JPG/BMP has been quite straight forward.
    TS
  2. DECEASED
    Jun 2009
    Heaven
    I think there is no way of doing that.
    NOTE : DevIL version 1.6.6 as shipped with Avisynth does not correctly support DIB/BMP type files that use a pallette, these include 8 bit RGB, Monochrome, RLE8 and RLE4. Because the failure is usually catastrophic, from revision 2.56, internal BMP processing does not automatically fail over to DevIL processing. Forcing DevIL processing for these file types is currently not recommended.
    .GIF files use a palette, therefore, ...
    Jul 2009
    Spain
    You could try using the Immaavs plugin, which uses ImageMagick.
    See http://www.geocities.com/wilbertdijkhof/
  4. I'm pretty sure VirtualDub can load a GIF sequence.
  5. Another option is to batch convert to .png (e.g. irfanview or other image editor)
