Hi All,
Here's the problem, I have recorded some videos with a crappy phone that doesn't get volume very well from a distance, so you can hear perfectly well the person who has the device but the person who is at a short distance is barely listenable. The difference between the two volume levels is too high.
The tool I normally use to edit video is VirtualDub and Windows Movie Maker. I could increase volume in Windows Movie Maker, but just the overall volume, which helped a bit but is not what I wanted. I could do nothing in Vdub. I proceeded to look into an audio software alternative. So I downloaded TMPGEnc to extract the audio from the video file and looked into some audio tools to fix the job to then re-encode the video with the newly fixed Audio file.
So far, the only way I found to fix this a little bit better is by using Goldwave and manually selecting each part of the audio file wave where the other speaker has low volume and manually increasing it. This is a very time consuming job and I was wondering if there is any other way I can perhaps try to bring volume levels closer to an average to avoid the high difference between speaker 1 and speaker 2/etc.
I am attaching an example of how much the difference between the sound levels is...
Anyone has any idea how can I do this properly? What tools should I be looking into and what filters/etc should I use to get the desired results? There has to be an easier way to do this...
Thanks!!!
example.wav
	That's a good suggestion for already-recorded material, but don't forget to work towards improving the WAY you're capturing the audio. as well. Better mike+recorder, better placement, more isolation/better directionality.
 It's alot easier to make a minor fix to something that is nearly there, than to make a major fix to something that is way off.
	I don't remember for sure. But I believe it was about:
 Threshold: about -60
 Ratio: 10:1
 Attack Time: 0.1
 Decay Time: 1.0
 Normalize...: enabled.
	awesome, i've been using this with a lot of my video files now. works beautifully!! tks guys! i luv this forum!
  best media player capable of high level h.264 video?By hiohaa in forum Media Center PC / MediaCentersReplies: 1Last Post: 2nd Mar 2012, 16:37
  Video Audio Volume levelBy Directlinq in forum Video ConversionReplies: 2Last Post: 16th Nov 2009, 13:43
  How do you know the volume level of each channels in a 5.1 track?By zee944 in forum AudioReplies: 2Last Post: 7th Sep 2009, 10:54
  Music volume is greater than people speakingBy Alvito in forum AudioReplies: 3Last Post: 24th Dec 2008, 18:23
  PSP Video Converter with good volume level?By akumaryu in forum Video ConversionReplies: 6Last Post: 2nd Sep 2008, 21:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
